Question about LG WM-2277HW Front Load Washer
The fabric softner chamber seems to be clogged because after a wash it is full of water.
    Problem Solver:
  • 6 Answers
The fabric softener chamber is likely full of crud and or mildew.
  1. Pull out the detergent / softener tray (press down on the tab in the back to get it all the way out). Take it and wash it as well as you can.
  2. Now, pull the washer out enough that you can get to the back of the machine.
  3. Unplug the washer!
  4. Remove the four screws holding the plastic tabs (at the top) on the rear of the machine.
  5. You should now be able to remove the top cover of the machine - slide it back and then up.
  6. There are four small hoses connected to the back of the detergent tray, and one large hose.
  7. Take a marker / tape / etc. and label these hoses 1,2,3,4 - write the corresponding number on the top of the detergent tray so you will know where to hook them back up!
  8. Using pliers, squeeze the tabs on the small clamps to loosen them enough to pull them back about an inch on the small hoses.
  9. Pull the hoses off, gently.
  10. Use a phillips head screwdriver to loosen the clamp on the large black hose. Pull it off.
  11. You may want to loosen the other end of this large black hose and remove the hose for cleaning. Mine was nasty.
  12. There is a black bundle of wires snapped into the sides of the detergent tray. Take this bundle out of the clips so it hangs loose.
  13. Remove the two screws from the front of the detergent tray. These are on either side of the opening and are usually hidden by the detergent drawer.
  14. Now, you should be able to slide the entire fabric softener tray back and out of the machine.
  15. The tray comes apart into two pieces - gently pry the tabs on the sides to separate them.
  16. Clean everything! If anything is too nasty / clogged to clean, buy a replacement part.
  17. Reverse steps to reassemble and good luck!
Posted on May 01, 2010
The fabric softener is clogged with dried up fabric softener on my Whirpool Washer. How can I get it cleaned out?
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
Feb 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
Aug 11, 2009 | GE Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Clogged fabric Softener
I had the same issue, and ran vinegar through the fabric dispenser with a load of towels. Not only did it solve the 'sour towel' problem I had with that load, it also cleared my fabric softener section. Now, I water down all fabric softner when I use it, which is less frequently!
~Steph
Nov 11, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Sep 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-2277HW Front Load Washer Logo
203 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
