Question about Zenith R56W36 56" Rear Projection Television
I just auto convergence my zenith tv and it fixed but still 3-D
I just auto convergence my zenith tv and it fixed most of the promblem but the colors are still not match up it still looks 3-D is there anything i can do
  • Zenith Master
  • 8,457 Answers
Ur tv convergence ICS are dead.That why ur colors lines green,red,and blue are not linning up,and the colors look like 3-D pic.Must have soldering tools,and know soldering to fix convergence problems.Must replaced 2 STK convergence ICS and some or all of it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Posted on Apr 29, 2010
  • Zenith Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.ji just auto convergence my zenith tv and it fixed  - 65af323.jpgh_mi
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 09, 2011
  • 666 Answers
Manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your proably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Zenith rear projection tv, left 1/3 of screen has color shadowing like colors are not aligning...tried adjusting with setup menu, but didn't work
Projection sets have two very common problems listed below. bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Apr 26, 2011 | Zenith R57W46 57" Rear Projection...
We have a Zenith 56 inch rear projection tv. Model num# R56W36. The picture did the 3-D thing on us when I hit auto-convergence button. We ordered new parts from TVRepairKits.com. Replaced parts and now TV...
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 22, 2010 | Zenith R57W46 57" Rear Projection...
I have a wavy 3d looking screen with weird colors
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Zenith R56W36 56" Rear Projection...
Zenith R49W36 Convergence issue
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Zenith R49W36 49" Rear Projection HDTV
Zenith R57W46 bottom bowing and color off and double lettering
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Zenith R57W46 57 in Rear Projection Television colors don't align
you will need to replace the convergence ICs and possibly the feed resistors. You can get the convergence repair kit at the following link and they send instructions that show how to replace the Convergence Ics. Heres the link look under the convergence repair kits category for your model.
http://servicemanuals.vstore.ca/
Feb 06, 2009 | Zenith R57W46 57" Rear Projection...
Pic prob.
WHAT DO I DO FOR MY AUTO CONVERG IT NOT ON MY SETUP OR MY PIC AT ALL MY TV IS OUT OF LINE BAD
Aug 23, 2008 | Zenith R49W36 49" Rear Projection HDTV
Zenith r56w36 56 in
My picture was fine but I had just got cable and wanted to make sure the picture was right. So I hit the auto convergence and now I have a 3 D look. I have never had any problems prior to this. What can I do? and what was is the problem? Thanks
Dec 19, 2007 | Zenith R56W36 56" Rear Projection...
Zenith R56W36 56" Rear Projection Television Logo
904 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
