Question about D-Link DIR-615 Wireless Router
When i install the router which is connected to a cable modem, using the setup cd i get an error message stating that the internet is not connected, the desktop pc which is connected via cable can access the internet but when i connect a laptop via the wireless it connects but i have no internet.
  • 2,263 Answers
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Posted on Apr 29, 2010
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
Cannot connect to network adapter
ask your internet service provider if there is a need for them to configure your modem for a username and password. please also check if the drivers of your network driver is installed to your pc.
Jul 06, 2009 | Belkin (F5D7230-4) Router (587009)
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
KEEP GETTING ERROR 321 WHEN SETTING UP LINKSYS WRT54GS ROUTER
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Still can't access the internet
It sounds like the internet connection is not working yet..Has it ever worked before? Did you have a normal non wireless router there before?
Jan 10, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless G CD will not install
Router setup
then:
Connect the Cat5 cable from the modem to the WAN port on the router. Then connect a Cat5 cable from any port on the router to your PC's network port.
Thanks, Joe
Nov 27, 2008 | Linksys Wireless-G WRT54G Router
Problems hooking up a Linksys wireless router
Please disconnect the USB cable that connected from the modem going to your PC. Now connect the ethernet from your cable modem to the Internet port of your router. Run the setup CD, that should guide you and will make you up and running connected to the router.
Nov 20, 2008 | Linksys Wireless-G WRT54GS Router...
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
My computer can't connect to Belkin Router through the wired internet
if the installation cd is getting an error message, it's better to manually configure it.
since you are using a cable internet, you can start by doing a power cycle. turn off all the devices first. then turn on the modem, wait for the lights on the modem to power on. then turn on the router, then the computer
if power cycle will not give you internet access. follow the steps below.
- access your router's setup page. open a web browser and type http://192.168.2.1. by default there's no password
- you would be prompted with the setup screen, go to connection type under internet wan
- follow the instruction or if you have the option, just set it to automatic configuration-dhcp, then clone the mac address
- after that, click on home, internet status should be set to connected
hope this'll help you and just ask me if you have other concern
ciao!
Jul 21, 2008 | Belkin (F5D7230-4) Router (587009)
CAN NOT SUCCESSFULLY INSTALL THE INITIAL SETUP.. HELP NEEDS..
Do you have your DSL set up with just the modem connected to one computer? You mentioned that "there is no internet connection problem without router". If you don't have the internet connection working without the router anyway, then how do you expect it to work with the router?
First, you need to make sure that you can plug in one computer to the modem and get an internet connection. This needs to be done with the Verizon Setup CD if you haven't done it already and by connecting your computer to the modem with the USB or Ethernet cable (you can use only one.) I would recommend using the Ethernet cable since this is what you will be using with the router. Once you have the Internet set up with one computer this way, then you can move on to the router.
Disconnect the computer from the modem and actually pull the power plug from the modem. Modems often will not reassign IP addresses when you change what device you plug into them, and thus need to be power cycled. Plug the ethernet cable into the WAN port on the Linksys (and make sure the other end is still connected to the modem) and plug the power cables of both the modem and the router back in.
You should now be able to connect your computer to the router with another ethernet cable (to one of the numbers ports, NOT the WAN port. This is reserved for the modem) and run the setup again.
May 14, 2008 | Linksys Wireless-B Broadband Router Retail...
D-Link DIR-615 Wireless Router Logo
210 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
