I am trying to enable UPnP on my belkin router (f5d7230-4). When I apply the changes I get the error message (Error password length ( should > 3 ). However my router password is set with an 8 character password.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
In the password one numeric character should there then only it will take
Posted on Mar 25, 2008
SOURCE:
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
Jun 29, 2015 | Belkin Computers & Internet
How do i enable upnp
Using your Internet browser, you can access the Router's Web-Based Advanced User Interface. In your browser, type "192.168.2.1" (do not type in anything else such as "http://" or "www"). Then press the "Enter" key.
Click login, the router comes with no password set, so unless you have changed the password, just click login.
To take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "Utilities" page. Click "Apply Changes" to save the change.
Oct 18, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hello FixYa, i've tried to open my nat for Xbox LIVE, by Port Forwarding, DMZ, UPNP, enabling NAT, what can i do to finally fix this problem?, this has been going on for 2 and a half years now.
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Aug 14, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless g mimo router. i never set a
When changing the advanced settings on the Belkin router, you should change the default password.
To change the password, go to Administrator Password. Type in a new password. Make sure you remember the password, otherwise, you will need to reset the router back to default settings.
I hope this helps.
Jun 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i connect ps3 to the internet using a belkin router
Hardwire your PS3 to router or connect it wirelessly by scanning from PS3....
Now hardwire your computer to any of the wired ports of the belkin router....
Goto start>run>type "cmd" >type "ipconfig" note down the default gateway address.....usually it ll be 192.168.2.1
now open any web browser and type the default gateway address in the address bar and hit enter.
In the belkin router set up page
Click FIREWALL and disable it....apply changes
click system setting and enable upnp....apply changes
click virtual servers and open the ports for PS3...and enable it...
that all...you are done with it...
you can also enable DMZ....it ll also resolves the issue....
Mar 03, 2010 | Belkin (F5D7231-4) Wireless Router
How do I enable my UpNp and access dmz
Hi jbourke,
Please find the below steps,
1.In the internet explore type 192.168.2.1 and click on enter
2.you will get the belkin router setup
3.in your left hand side you will see the menu sysem settings at the last,click on it.It will ask for password leave it blank and click on submit
4.you will have the UPNP option enable it and click on apply changes
FOR DMZ
1.In your left hand side you will see DMZ,click on it,if it ask for password then leave it blank and click on submit
2.get the ip of the PS/3 it will be in the range of 192.168.2.
3.select the enable and type the ip address in the page and click on apply changes
Regards,
Ayyasam
Jan 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Since using the belkin f5d5231-4 cabled router i have been having problems with world of warcraft. ie. disconnecting every 5 mins or so i have opened all the correct ports and still no solution plz help
You need to open the port numbers as follows,
1.TCP--->3724,UDP---->3724,28960
2.Check wither UPNP is enabled in router,to check this follow this steps
A.type 192.168.2.1,in the internet explore
B.in the belkin router setup page,the last option in the left hand side click on system settings,it will ask for password,leave it blank and click on submit
C.enable it and click on apply changes
D.in the left hand side click on firewall,and disable it
E.enable the DMZ for the particular IP in the Router
Regards,
Ayyasam
Dec 31, 2009 | Belkin (F5D5231-4) Router
PS3 cant go online with Belkin N150 (I think) wireless router
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings for the UPnP function and disable it. If you haven't changed the password on the router, the default password is blank, i.e., no password.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 15:Enable UPnP
Open Router setup
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
How do I change the Upnp settings on my router?
Linksys Routers are one of the best Home wireless routers. it has good security feature and better wireless length. To change the Upnp setting on your router
follow these steps
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1).Press Enter.
Step 2 The default username is admin (all lowercase) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab then click Misc. to the left.
Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wirelessrouter, or select Disabled using the radio buttons to disable it.
Step 5 Click Apply and then click Continue to save the new settings.
Read more for setup linksys router
How To Setup Linksys Wireless Router In 5 Min Fixingblog com
Jun 07, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
Computers & Internet Logo
162 people viewed this question
Ekse
Alun Cox
