Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
I have a Hampton remote ceiling fan with lights.The Redington 11
Model 175 620. The remote stopped working. Ireplaced the battery. The I.R. light works.No fan or light responses from remote. The fan is 17 years old. It was working fine the would not turn on. Have you any suggestions.? Do the reomotes just suddenly not work even thought they send a signal.? gwgerold@comcast.net
  • 666 Answers
Its more likely the fan itself has burnt out each universal control comes with a means to manually enter a code to if you have one with the manual you amy be able to set the ceiling fan frequency to a preset to be used if your fans remote is the issue
I think before trying to program it into another remote you make sure in whatever way you can that the fan itself can be turned on manually by hand so you know that it is not the issue
hope this helped
Robb
Posted on Apr 29, 2010
Testimonial: "Thank you. Since the lights failed also Iwill have to search further."
  • 3 Answers
The carbon of remote which help to connect the points of remote is not working so purchase the liquid carbon and put on the inner points on remorte buttons
then i feel it strt working.
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Aug 16, 2009 | Hunter 28156 Cote 54' d'Azur® Ceiling Fan
Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
May 27, 2009 | Hampton Bay 52 In. White Redington...
Light comes on and off automatically
It sounds to me like someone close by may have a remote that is to thier device and its changing yours because its on the same codeing!
Dec 15, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Dec 08, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
1,422 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
