Question about GE 19TVR62 19 in. TV/VCR Combo
SAP off How do I turn off the SAP when it is not an option in the menu?
  • 666 Answers
Most likely the controller it came with has the option on it probably abbreviated if not you will want to check the manual if you end up needing a manual download for the user guide let us know we can get it to you quickly
Hope this helped
Robb
Posted on Apr 29, 2010
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Some of my channels are in sap and I don't have an audio option on my menu nor the orignal tv remote. How do I change it?
Sorry the SAP function are only can be change in the Audio option menu or the tv original remote only that have the SAP button.Try website like Remotes.com to buy the tv original remote.
Apr 19, 2011 | iLO IWT3206 TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
How can i turn off the sap? I have used the setup menu, but when i get to the sap mode the arrows on the remote do not work.
Here are a few suggestions to help you with this problem:
1. While in the setup menu, and you are at the SAP mode, before using the arrows on the remote, hit the OK button, then the arrow on the remote. It is possible that when there is a drop-down menu involved, rather than just an on-off choice, the DVD is set to have to hit OK first to "lock down" the submenu.
2. Check to see if your DVD setup menu has more than one available language/closed captioning option in different areas of set up. For example, depending on your brand, there may be options available in general set up as well as video set up.
3. Check to see if your remote has audio and subtitle buttons. If you cannot set your options through the menu, it is possible with those buttons to chose the language and captioning options as you are watching.
Hope this helps you.
Feb 21, 2011 | Televison & Video
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
Where is the sap button on the remote or tv screen?
There would not be a SAP button on newer tv's. You will need to access your TV's main menu, go under Audio or Sound options and search through till you find the "language" or special features area. If your tv has the SAP function, you will find it in the menu.
Jan 18, 2011 | Televison & Video
No sound on a few channels. all others have sound. 26 in vizio.
Since you have sound, the audio circuits are working. The most common cause of this is to have the TV set to use SAP. There are many channels where this is an unused option and others that broadcast the same audio on the standard channel as well as SAP. If you change the channels and get Spanish rather than English for example, you have SAP turned on. Check the audio menu for SAP status.
Let us know what you find.
Dan
Dec 06, 2010 | Vizio L32 32 in. LCD HDTV
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
On channel 25 on
hi,
try using menu button from tv go to audio menu and see if you can find sap option,if not try buying an universal remote,program it to work with tv and pull the menu, that should fix problem,thanks,faradio.
Mar 29, 2008 | Televison & Video
GE 19TVR62 19 in. TV/VCR Combo Logo
253 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
