Question about OfficeMax 0M96431 Shredder
I HAVE A FELLOWES PAPER SHREDDER, MDL. PS 60CC. CAN YOU HELP WITH THIS MACHINE? THE MOTOR RUNS BACKWARD, BUT NOT FORWARD. THE LIGHTS DO NOT COME ON. I HAVE CHECKED TO SEE IF JAMMED//NO. HAVE TURNED MACHINE ON AND OFF. NOTHING HELPS.
  • 560 Answers
Unplug the shredder and look for sensors in the center of the opening in paper entry area. To find the sensors, lift the safety flap over the cutting mechanism. Use small pliers or tweezers to clear away any debris and chunks of papers stuck under the sensor and cutting mechanism. You may have paper chunks blocking the sensor in forward motion. This can happen after a reverse/backward operation.
Posted on Apr 29, 2010
    President:
  • 2,468 Answers
There a forward/reverse switch located on the upper part that you must have inadvertently switched,in forward it runs off of the paper being fed manually into the unit thru a micro-switch,in reverse they run full time to back feed any paper that is jambed,make sure switch is properly positioned and then also make sure there are no paper scraps loged in the cutter allembly feed path
Can you put oil or wd40 in shredder
I own a Fellowes PS 60 shredder.
NO! Do not use those lubricants.
I have used Silicone lubricant for many years and it does not and has not caused any problems in my PS60. Spray it across the top of the cutters and manually run the shredder (without paper) forward and reverse for a few seconds. This will lubricate all the cutters. I do this only once until my collection bin is full. Once full I empty it and lubricate once again.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Aug 15, 2013 | Fellowes Powershred PS-60 Shredder
Wiring diagram for a Fellowes PS 60CC shredder
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
Jun 29, 2012 | Fellowes Powershred PS-60 Shredder
Need a new (3 way) switch for my fellows ps 60cc shredder where can I buy one from...can you send me a email address?
fellows # 800-955-0959 they take credit card.
Hope this helps leave feedback. Have a nice day
May 15, 2010 | Office Equipment & Supplies
Fellowes Powershred PS 60CC stopped working
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
The plastic gear in my Fellows Powershred PS 60CC paper shredder is ruined. Is it possible to buy a replacement gear anywhere?
WHICH OF THE PLASTIC GEARS FAILED? FELLOWES HAS A REPLACEMENT THAT CHANGES A PLASTIC GEAR TO A STEEL GEAR-A GREAT IMPROVEMENT.
Oct 06, 2009 | OfficeMax 0M96431 Shredder
Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
Jun 09, 2009 | Office Equipment & Supplies
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
Fellowes PS-70 Shredder jam
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Jun 13, 2008 | Fellowes PS70-2CD Shredder
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
OfficeMax 0M96431 Shredder Logo
173 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
