Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have just purchased a used wd52525, nice TV, but I don't know how to make it connect to my DVD player or other electronics. Is there a quick easy process to this that I am overlooking? Any help appreciated.
  • 99 Answers
If you dont have the owners manual, here is one:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
check page # 13, you have to connect your dvd and other electronics to that part.
Posted on Apr 29, 2010
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Have connected headset through cable box works very well for t.v. Not at all using DVD player.any suggestions?
Hi
Just a thought but how is your DVD connected to the TV?
If the DVD player is connected to the TV and the headphones to the cable box, then the audio will be going direct to the TV and no chance for the headphones to pick it up.
If however the DVD player is connected to the cable box and then to the TV, I think I would expect it to work and cannot think of a reason why not.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Unisar Extra Headset For the Tv Listener...
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
I have and old emerson tv (ewt19s2) that i want to use a dvd player with. the remote isnt working. what can i do to the tv to make the right screen work?
HI JENN,
I ASSUME YOU DON'T HAVE A REMOTE FOR YOUR TV EITHER SO...
I WOULD EITHER PURCHASE AN INEXPENSIVE UNIVERSAL REMOTE COMPATIBLE TO THE DVD PLAYER AND EITHER USE PATCH CORDS, OR AN A/B SPLITTER, SO YOU CAN GO OUT THE DVD INTO THE TV...THE SAME AS YOU WOULD HOOK UP A VCR.
YOU DON'T NEED A REMOTE FOR EITHER, YOU CAN TURN BOTH ON AND OFF MANUALLY...
YOU ONLY NEED TO MAKE SURE THE TV IS SET TO THE SAME CHANNEL AS ON THE DVD PLAYER 3 OR 4.
HOPE THIS HELPS! I WOULD APPRECIATE A RATING FROM YOU.
KIND REGARDS!
MARTIE
Sep 08, 2011 | Televison & Video
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
Jul 19, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Have just purchased Toshiba 32kv500b tv and as there is only one scary socket don,t know how to attach a dvd player can you help with this problem please?
Connect the cables from your dvd player to the connections on the side, not the back, of the tv. If you are using component cables, match the colors in the 3 top ones (YPbPr) and the red and white go down into R&L just above the headphone jack. If you are using composite the plug the yellow just above the R&L connections.
Jul 06, 2011 | Televison & Video
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Tv/digital converter box & vcr-dvd hook-up
Hi Karen, I think you are having connection issues. Can you provide specific details of the connections? Thanks, Mike
Nov 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith TV
have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Dec 28, 2007 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
