Question about HP UPS R3000 XR (192186002) UPS System
Just replaced a battery module for HP R3000 XR and after plugging in the power, all LED's are flashing red. can't find anything in manual that tells me what this means.
  • 51 Answers
SOURCE: Utility LED flashing green/red
Seems like your Battery is very low. Try charging the battery for a few hours. If the problem persists, it maybe the time to get a new battery.
Like all batteries, UPS Batteries (that store electricity and let s you use it in case of a power failure) have a limited life. This life is averaged to be around 2 years. So in case your UPS has been in use for approximately that much amount of time, the battery is in a near death situation.
For instructions regarding replacing the battery, please refer to your UPS Manual.
PS: Also, I have noticed this kind of behavior when the UPS is connected to a socket powered by an Inverter. This kind of behavior is observed when the Inverter battery is running low.
Posted on Oct 17, 2007
spike888ph
  • 77 Answers
SOURCE: flashing battery power LED
Try this
1. Remove the battery and the AC adapter. Hold down power button for 5 seconds. then insert the AC adapter only and see if you can power up the laptop. if it does power up, dont use the Battery anymore as it might be the cause of the problem
Posted on Apr 07, 2008
  • 477 Answers
SOURCE: i have a hp pavillion
count the times the green led flashes? and how it flashes that´s an error code for your problem. it can be the motherboard or power.
Posted on Aug 13, 2008
SOURCE: hp dv2000 won't turn on...
dude, I almost gave up.. try this link. Apparently lots of people experienced this problem so HP gave an extended warranty for models like these.
Here, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Posted on Nov 29, 2008
projdoc
  • 2237 Answers
SOURCE: no display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Posted on Aug 10, 2009
Honda xr signal LED lights not flashing
Hi, Anonymous before testing any electrical component in the Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion.
If all four turn signals flash at the same time like hazard lights even though you only pressed one turn signal button then you have a LED light in the circuit and need a load equalizer that can be purchased from any motorcycle parts supplier.
If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function.
If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction.
If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, the harness connector is usually located under the seat on the front of the rear fender then keep tracing the wiring look for obvious harness damage caused by the rear tire.
If you still can't find the malfunction backtrack from the rear fender wiring harness connector.
If one side does not work you could have a faulty turn signal switch or module check for continuity.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Make LED turn signals flash
XR650L LED Turn Signal Problem 4Strokes com
MANUAL HONDA XR400
http://www.partsfish.com/page/oem-parts-for-honda
HONDA XR400R Owner Manual
Apr 05, 2014 | 1998 Honda XR 400R
HP Designjet 500 has a locked screen. I have been trying to get the plotter to run on our new computer and it locked up after installing the current Firmware and driver updates. Any suggestions would be...
Dear Friend, It's a serious issue what I understood & confusion is control panel locking facility not avail in this model, how its locked?.. Simple method to catch the faulty part through power LED behaving s..(Power led located on power button)
# LED is OFF - This indicates that the Power Supply Unit is
completely dead. Try the following:
1 Check that power cord is connected correctly to the Printer and to the Power Socket.
2 Replace the Power Supply Unit
# LED is ON (all the time) - This indicates that the Main PCA is completely dead. Replace the Electronics Module
# LED is Flashing - A problem has been detected with the previous firmware upgrade. Try re-send the firmware upgrade file.
# LED Flashes twice every few seconds - The Printer cannot detect the Interconnect Cable. Try the following:
1 Check that the Interconnect Cable is connected correctly to the inter connector PCB & Electronic module.
2 If the Interconnect cable is connected correctly and the LED continues to flash twice then replace the Interconnect Cable
LED Flashes 3 times every few seconds - The Printer cannot
detect the Front Panel. Try the following:
1 Check that the Front Panel is connected correctly to the Interconnect PCA.
2 If the Front Panel is connected correctly and the LED continues to flash 3 times then replace the Front Panel
LED Flashes 4 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module
LED Flashes 5 times every few seconds - This indicates that the Electronics Module has failed. Replace the Electronics Module.
Now U decide that whether firmware uploaded properly or not?..if not its sure that Electronic module gone.. you have 2 replace it..
Any further help/query pl reply, best of luck..
Oct 02, 2013 | HP DesignJet Office Equipment & Supplies
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
HP3000 XR UPS units utility light is green and not flashing The Battery light and the General Alarm light are flashing red
If you have had the UPS for more than 5 years you will need to change the battery ... you can source replacement batteries and not have to replace the whole UPS.
Birket
Jul 14, 2011 | HP 3000 XR (j4367a) UPS System
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
I now live outside the US and brought my compaq ups r3000 xr with me and am having a problem getting a receptacle to plug it into. my electrician needs a part number as he has never seen that type of...
First of all you should make sure that the UPS is capable of handling the mains voltage from the country you're into now. After that just cut the cable as close as possible to the old mains plug then add a new one - all you need to be sure is which is the ground wire and that is very easy to find out with a simple ohmmeter. When you will go back to the US all you will have to do is to replace the plug.
Sep 12, 2010 | Compaq UPS R3000 XR UPS System
Compaq UPS R3000 XR Comms cable
Hi Jon,
so we could use this link it as a solution for your problem?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=3447589&prodSeriesId=255222&lang=en&cc=us
Kind regards,
noris017
Feb 25, 2009 | Compaq UPS R3000 XR UPS System
Will not turn on at all
i also have no lights, no action at all,
after taking the unit apart i've noticed a number of little red buttons hopefully one is for some sort of charging system reset, i talked to compaq and they wouldn't tell me any thing about the buttons. however i've found a couple sites clamming to have service manuals for free.
im looking into that now
May 04, 2008 | Compaq Presario R3000 Notebook
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
Oct 12, 2007 | Compaq UPS T1500 XR (204155-B32) UPS...
HP UPS R3000 XR (192186002) UPS System Logo
391 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
