Question about Samsung SP50L7H 50" HDTV-Ready Television
Ive got a rear projection tv why does the screen keep goin black when the sounds still on and the bulb?
  • 336 Answers
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Have a blessed one!
Posted on Apr 29, 2010
Got a Mitsubishi vs-8070, everything works fine then the screen turns off after about 15 minutes sound still works fine. Help.
Does this unit have a projection bulb in the back end of the set? Just based on my experience with a friend's 65 inch rear projection TV, there might be an indicator light on the front panel that may blink if the rear projection bulb is failing. If there is a failing bulb it could account for the screen going black with everything else just fine, after the bulb gets heated up in 15 minutes.
Oct 15, 2014 | Televison & Video
I have a Sony KP-61XBR-300 rear projection tv---- Picture went out. Is this the light bulb and if so where is located. Can I get it out myself?
This is a projection TV: it uses cathode ray tubes instead of bulbs. If you have a black screen, but still have sound, then the problem is on one of the circuit boards. Very few parts are available for this model.
Dec 05, 2010 | Sony KP-61XBR300 61" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Nov 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
TV turns off..lamp light flashs
I have one of these. It sounds like your projection light bulb has burned out & it needs to be replaced. Last time I checked (2 years ago), they were about $200. They are not hard to change if you are handy. Follow the directions, do NOT touch the bulb with your bare hands, use gloves or the oil from your hand will cause it to burn out prematurely. If you are not handy, call for a repair person.
May 05, 2009 | Samsung HLN567W 56" Rear Projection HDTV
46 inch rear projection tv bulb replacement model number 46gw944
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Feb 05, 2008 | GE 46GW945 46" Rear Projection Television
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Black screen
Sounds like the bulb again. In the manual it says that the power light flashes to let you know that the bulb is bad. When I got a replacement bulb, I noticed that the wiring on it was opposite of the one on my set and had to change the wiring to match my set.
Jun 02, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung SP50L7H 50" HDTV-Ready Television Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
