Question about Brother IntelliFAX 4100 Laser Fax
Keeps going to manual feed will not print - Brother IntelliFAX 4100 Laser Fax
  • bbaa4 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
2 Suggested Answers
  • 59 Answers
SOURCE: Brother printer will not print because I keep getting manual feed
thios means the job you sent to print was detected as a differant size then the paper in the tray.
you would have to put a page in the front slot of the machine until it clears out this job
Posted on Mar 24, 2010
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Mar 24, 2010 | Brother HL-4050CDN Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Dulex printing???? for HL 2040
The way that I know to do it is to indicate that you are going to manual feed when printing. hit print
Then feed the paper into the manual feed slot, noting the correct direction in the diagram in the paper feed area. Once the first side prints then feed the paper through the manual feed slot, again following the directions in the diagram.
Feb 13, 2009 | Brother HL-2040 Laser Printer
Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
Dec 04, 2008 | Brother HL-5240 Laser Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Hp 4350 - Manually feed not printing on its own
from the configuration menu you most select the manual tray and keep it first
Mar 12, 2008 | HP LaserJet 4350 Printer
Brother IntelliFAX 4100 Laser Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
