Question about Bosch Washing Machines
I am looking at buying a second hand (2002) Bosch Maxx frontloading washing machine. The advertisement says that it keeps turning off before the cycle finishes. Can you tell me whether this is likely to be an expensive problem to fix? (I live in NZ).
  • jane_cooper Apr 29, 2010
    Very helpful indeed, thanks
    President:
  • 2,468 Answers
It will be the e.c.u. that will need to be replaced as this is a problem with this brand of machine,possibly $150.00 for the board plus any labor per hour that your area charges. thank you and please rate this answer if it helps you
Posted on Apr 29, 2010
Bosch maxx Classic. 7 yo. Washing cycles are not finishing. Timer is showing 1 but does not turn off. Clothes are still quite wet. Have cleaned filter. Anything else I can do?
Looks like the solenoid that controls the drain motor is malfunctioning.
Whenever this happens, the water does not get drained fully and remains in the chamber thus keeping the clothes still wet.
Speak to your local service representative and get the part replaced.
Feb 22, 2015 | Bosch Washing Machines
Why is my bosch maxx classic frontloader washer tripping the safety switch in fuse box
hi rachel, there's a bad earth in the machine some where,things to check wiring to the motor, check the wiring it's self, any circuit boards, if they are all ok the programmer could be shorting out hope it helps
regards
shaun
May 17, 2012 | Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Oct 10, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
