Can't get the hard drive out of the 8570 C Medallion HP
I can't find a manual that describes how to get the hard drive out of the computer. It has two screws on the outside. There must be screws on the inside connecting the hard drive to a fitting. Does the whole cage come out? How?
Thanks
Wes
w
  • 1 more comment
  • wes11 Mar 25, 2008
    Thanks!
    It sures is a lot easier with pictures.
    wes11
  • Kevin Miller May 11, 2010
    Depending on the PC, the cage may have to be removed. I assume you have already removed the power connection and other connections to the back of the drive. But, as melnavz said, it is necessary to determine the computer model first.
  • Anonymous May 11, 2010
    What is your pc model or the make? removinf hard drive depending on the model of the PC it vey easy if it is clown pc that is very easy to remove. but anyway just provide info about your pc.
  • 667 Answers
For your HP Pavillion 8570C, follow this link and it will give instructions with diagrams. I could tell you how to do it nut it's much easier to read these and see the diagrams. Hope this helps. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph05032&lc=en&cc=us&dlc=en&product=58698&lang=en
Posted on Mar 25, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 25, 2008
    Please rate if this helps. Thanks.
    Genius:
  • 1,226 Answers
Hello.
i guess the issue was resovled by
oldnovii
, but if not then better provide as a picture. thank you for using fixya. melnavz
Posted on Mar 26, 2008
6ya staff
SOURCE:
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
Hi i have a compaq nw8240, im having some trouble turning it on i press the power button and the screen with the hp logo appeas but thats it it will stay like this even when i press f10 (based setup)...
Hello
Make sure no external device is plugged in like a USB ,network cable device.
It could also be a bad hard disk remove it and try and see if the computer will boot past the HP logo ,here is the user manual on page 99 it describes how to remove the disk:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00384165/c00384165.pdf
If it boots properly without the hard drive then it will have to be replaced.
Good Luck
Mar 01, 2012 | HP Computers & Internet
I have a HP Touchsmart 610 and want to copy a DVD (not copyrighted) into my computer and make copies. Is the info in a manual, and if so how do I find the correct manual online? Thanks, Jim
You'll find the manual on the HP support web site:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=5039931&docIndexId=64255&printver=true
If this url doesn't work just google hp touchsmart 610 maual.
To copy a dvd to your hard drive for future copies is essentially as described here:-
http://www.magicdvdripper.com/copy-dvd-playback.htm
The software is different but the essentials are the same.
Sep 19, 2011 | HP Computers & Internet
Error E010
"E010" Drive problem
http://www.manualshark.org/m/canon-np6150-6650-6650ii-7050-7550-8070-8530-8570-8580-black-994/
http://eshop-manuals.com/index.php/cPath/4
Above is a service manual a MUST HAVE in order to fix, above that is a user manual, for troubleshooting.
Apr 28, 2010 | Canon NP 6650II Copier
I HAVE A HP DV6700 LAP TOP HOW DO YOU CHANGE THE HARD DRIVE
The official service guide:
http://h10032.www1.hp.com/ctg/Manual/c01295877.pdf
Nov 13, 2009 | Computers & Internet
HP 8570 C Medalion hard disk removal
The side panel of the case should be removable to gain access to the screws. I have also seen versions that the card cage itself is on a hinge, and swings out of the case (with the removal of a few screws) that then gives access to the drive screws.
Mar 25, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
323 people viewed this question
Ekse
Marvin
Marvin
