Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
How to change heater core in a 92 cadillac deville
  • 10,515 Answers
The Generic Procedure is :-
This information is assuming you have a "Automatic A/C system" if you do not please let me know.
HEATER CORE
Removal & Installation
1. Disconnect negative battery cable
. Partially drain coolant. Remove glove box. See GLOVE BOX. Remove right lower sound insulator. Disconnect electrical connectors. Remove ACM. See A/C-HEATER PROGRAMMER. See Fig. 7.
2. Remove heater core cover. Remove inlet and outlet hoses from heater core. Remove 2 heater core retaining screws. Remove heater core. To install, reverse removal procedure. Fill cooling system. Perform air mix valve adjustment. See TEMPERATURE AIR MIX VALVE under ADJUSTMENTS.
GLOVE BOX
1. Disable air bag system. See AIR BAG SYSTEM SAFETY article in GENERAL SERVICING. Open trap door in rear of glove box. Disconnect passenger-side air bag module wiring connector from retaining clip on rear of glove box. Remove glove box light lens by gently prying release tabs. Gently pry top of switch cover to release tab.
2. Reaching through light opening, push switch outboard. Disconnect electrical connector, and remove switch. Remove 6 glove box-to-instrument panel screws. Remove glove box. To install, reverse removal procedure
DISABLING SYSTEM
WARNING: SDM maintains sufficient voltage to cause air bag deployment for up to 10 minutes after ignition switch is turned OFF, battery is disconnected, or fuse powering SDM is removed.
In order to begin servicing immediately, air bag modules must be removed from deployment loop. NOTE: When SIR fuse is removed and ignition switch
is in RUN position, AIR BAG warning light will be on. This does not indicate a system malfunction.
Frontal Air Bag System
1. Turn steering wheel to place vehicle wheels in straight-ahead position. Turn ignition switch OFF and remove key.
2. Remove SIR fuse (20-amp) from trunk fuse block, located behind carpet in left front corner of trunk. Remove left sound insulator panel. Remove Connector Position Assurance (CPA) clip and disconnect driver-side Yellow 2-pin connector near base of steering column.
3. Remove glove box. Remove CPA clip and disconnect passenger-side Yellow 2-pin connector.
Disconnect negative battery cable. Remove right sound insulator. Remove glove box. See GLOVE BOX. Disconnect programmer electrical and vacuum connectors. Remove A/C-heater programmer. See Fig. 7. To install, reverse removal procedure.
Actuator Calibration
After actuator replacement, actuator must be recalibrated to ensure proper valve travel. Cycle ignition switch to ON position for 3 minutes to allow programmer and actuator(s) to recalibrate travel. For driver or passenger link rod adjustment, see appropriate link rod adjustment procedure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 29, 2010
How come when I start up my 1999 Cadillac deville I smell antifreeze real strong through the vents ? Is something wrong?
The heater core may be leaking / faulty - not familiar with Cadillacs, but normally it is located inside the car, behind the dashboard (glovebox) on the passenger side (near the blower motor). This may be something for a mechanic to diagnose if you are not familiar with automotive heating/cooling systems.
Mar 02, 2017 | 1999 Cadillac DeVille
How to install heater core for a 1995 Cadilac Deville 4.9L
you must remove the clamps from the heater core from the engine compartment and the covers from under the dash to be able to remove the heater core
Feb 24, 2015 | 1995 Cadillac DeVille
98 caddy deville nothstar v8 how to replace heater coil have no heat and I'm loosing water somewhere
the heater core in a 1998 Cadillac is very tricky to replace.
start with getting a pressure test to determine where the exact location of the leak is, it may not be the heater core.
if you do decide to pull the dash apart to change the core make sure the battery is disconnected for at least an hour to allow the airbag system to discharge.
Oct 11, 2012 | 1998 Cadillac DeVille
My cadillac is not giving me any hot air ,ive replaced the radiator, changed the thermostat, has a new water pump, where do istart to look.
Feel the 2 tubes at the firewall for the heater core. If they are not getting hot, the heater core needs to be flushed out or replaced. I had this problem with a 1990 Cadilac Deville, it was just a plugged up heater core.
Remember to install sealant after flushing out the system to prevent leaks.
Jan 25, 2011 | 1992 Cadillac DeVille
How do i replace a heater core in a 1999 cadillac deville
Here is detailed solution on how to replace the heater core in the 1999 cadillac deville;
STEP 1 Disconnect the negative battery cable.
STEP 2. Drain and recycle the engine coolant.
STEP 3. Disconnect the heater core hoses using tool J-37097 or an equivalent.
STEP 4. Remove the right side sound insulator and the glove box module.
STEP 5 Remove the programmer shield, if equipped, and disconnect the air mix valve link.
STEP 6 Disconnect the programmer vacuum and electrical connectors.
STEP 7 Remove the heater core cover, leaving the programmer attached.
STEP 8 Remove the heater core retaining screws and the heater core.
have a nice day..
Aug 27, 2010 | 1999 Cadillac DeVille
92 cad deville, blower works, but no warm air...
check thermostat,flush your system rad or heater core could be clogged
Jan 12, 2010 | 1993 Cadillac DeVille
I have a 1991 cadillac deville
I have a 92 Deville. All the flushing in the world will not fix the cloged up heater core. The flush will clean out the passenger side of the core but will not clean the core on the drivers side. I have just repaced my core and seen how these fail, It is a bad design that caddys are known for. It was recomended I do a total flush of the system every 30,000 and then just maybe I would not have to endure the core change again. As the antifreeze runs through the car it does a chemical change due to all the different metals and rubber it flows through. since the heater core is small with small bands to let the coolant in and out, it builds up with the sludge from the chemical change. Thus closing off the drivers side first. Note, both the inlet and outlet are on the passenger side, you really cant flush fluid where it builds up the sludge in the core. Solution, new core after trying a flush
Dec 18, 2008 | 1992 Cadillac DeVille
63 cadillac sedan deville heater core removal and installation instructions
I do think you have to pull he dash, for that you will need a manusl, try ebay for used factory manuals, I have had good luck getting them there for all my cars.
Oct 17, 2008 | Cadillac DeVille Cars & Trucks
Heating & Cooling Logo
230 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
