Question about Nextar X3-03 Car GPS Receiver
GPS IS FROZEN IN THE DOWNLOAD SCREEN.
MY GPS WILL NOT RESET OR TURN OFF.IT IS STUCK IN THE DOWNLOAD SCREEN. I RECEIVED A WARNING SCREEN WHILE THE GPS WAS GIVING ME DIRECTIONS AND THEN IT RESET ITSELF AND FROZE.
  • olead53 Apr 30, 2010
    In the process of letting it drain. will plug it up in the next half hour. I would like the thank Al for the positive solution he posted. In todays economy, everybody just can not turn around and buy something new when the old one just might have a little glitch. Keep up the good work Al.
  • 843 Answers
I have had similar problem and was able to solve it only by allowing the device to run on battery until it had completely run down. Wait an extra hour or so to be sure, then plug it in again. It's almost certainly a software problem, and there might be a new version available once it comes back up. Good luck, thanks for using FixYa.
Posted on Apr 29, 2010
Magellan screen frozen
assuming you have the 2200 as listed in your category, depending when your 2200t was made, it could either have a push type (one you would use a paper clip to reset) or a slide switch.
both are located in the same position (on the left side, bottom under the flap right under the sd card slot)
turn on the gps till you get to the warning screen, then reset it.
if its is the early model with the slide switch, youll have to move it back to the other position and restart it..
if that fails, i would try the latest update, well actually i would install the update either way, whether the reset works or not.
you can get the update HERE
let me know if you need further help
bill
May 24, 2010 | Magellan RoadMate 2200T GPS Receiver
Nuvi is frozen on warning screen. Won't reset by hoding power but
If you haven't already done so, I would suggest you connect to Garmin.com, register your device, and download/install the WebUpdater.
Then connect your unit to your computer using the USB cable that was included. This will start your unit in a very different mode (it will appear as a storage device to your computer), which WebUpdater will recognize. WebUpdater will check the current release level of your unit's software and let you update it to the latest version. The update process may well cure the problem when next you start the unit in GPS mode.
Good luck.
Jan 25, 2010 | Garmin nuvi 255W GPS Receiver
As soon as i turn on my gps it starts to boot up
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Jan 24, 2010 | Garmin n?vi 265WT Car GPS Receiver
Frozen Screen
Mine does this from time to time. I pull the SD map card, power it off, and hit the reset button while the unit is unplugged. These units are notorious for this. But then again, they're inexpensive. No receipt ... well, you're pretty much stuck with it. No receipt, no return or repair.
Sep 15, 2009 | Nextar X3-02 GPS Receiver
My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jul 27, 2009 | Garmin Nuvi 760 Car GPS Receiver
Frozen screen, wont turn off
hit the reset button on the bottom with the power on...it will reset ..
Feb 25, 2009 | Tomtom ONE GPS Receiver
Garmin 250
Did you try pressing the reset button on the bottom. Its located under the decal. You should be able to press it without having to remove the decal. If that doesn't work, please let me know.
- Jim
Dec 08, 2008 | Garmin nuvi 250 GPS Receiver
Navman iCN 550 GPS frozen on start up screen and makes a noise like it is stuck
Try hitting your reset button if you haven't already. I had the same problem and this worked for me.
May 15, 2008 | Navman iCN 550 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
184 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
