Question about Insignia Televison & Video
When I put a DVD into the player the screen goes off and on and it flickers with lines running through the middle of the screen. The sound cuts off and on at the same time.
  • Insignia Master
  • 3,866 Answers
Let me give you the probable causes:
1. dirty disk
2. scratched disk
3. bad laser optics
4. bad laser to decoder board
Ok I started from the most common to the least common since the unit is not under my eye's here (not on my bench).
Things to try:
1. cleaning kit
2. pop the lid of with a cue tip wipe the laser clean with some alcohol.
3. Try different video audio connections (huntch)
4. follow steps 1 and 2
Now if these helps do not work then the unit will need repair by a local shop (probably cost just a few dollars under what it cost for a new unit)
Please do click the accept button for my efforts, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 29, 2010
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Screen just flickers when I put a disc in the player.
My dvd player will show the movie for awhile the it would stop turning and go any further. I would say it plays for 15 minutes any suggestions
Jul 21, 2008 | Dynex DX-PDVD7 Portable DVD Player
Distorted picture
I am having this problem too any ideas
Jan 15, 2008 | Televison & Video
Craig portable dvd player CTFT701
My screen would flicker when you tilted it back and forth. Sometimes it would cut out and moving it would make it come back on. I took the battery off and opened the screen from the front(2 screws in hinge & 2 screws under rubber plugs). There is a ribbon plug inside. Mine looked kinked in one spot so I just repositioned it so the kink was in another spot. Everything worked fine after that. Hope this helps.
Aug 03, 2007 | Craig 731398407019 Portable DVD Player
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Televison & Video Logo
16 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
