Question about Sebo Automatic X1 Bagged Upright Vacuum
My Sebo automatic X1 has stopped working Every time I attempt to switch it on the only thing that happens is the bag and roller warning lights flash briefly. This suggests the power is ok but the Sebo doesn't start. Any suggestions?
  • 144 Answers
Check for clogs, and also check the brush rollers' belt.
Really, i think you should take it to a vacuum shop and have it inspected for problems
Posted on Apr 29, 2010
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Faithful Sebo X1 upright, about 12 years old, stopped working today. I replaced old with new dust bag, checked all dust paths were clear, checked main brush was clear/clean, and drive spindle rotated OK...
At 12 years, this vacuum has had a good long life. I suspect the motor is shot, but it could be due to faulty wiring and connections. A bad switch, break in the power cord, and worn brushes in the motor are other causes.
I recommend taking it to a shop for diagnosis and repair. You may be better off buying a new vacuum if the cost of repair and parts seems excessive.
Mar 01, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
May 18, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
428 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
