Question about KitchenAid KESK901SSS Electric Kitchen Range
KitchenAid KESK901SSS Oven door wont open after blackout
Hi, I experienced a blackout and when the power came back on the oven door locked status was on. I tried cutting off power and rebooting, but that didn't work. Also tried to turn on self cleaning, then canceling it to no avail. Any ideas?
My kicthenaid oven door locked when a breaker tripped. I live in a sm. town. Some of my friends had to cut through the metal lock, then take the whole thing out the back of the oven along with some kind of spring. Don't try this at home. And make sure the power is turned off. These "Good 'Old Boys" can fix everything - and without the manual. The good news is that you don't have to pay a service man or buy parts. Just don't ever turn on the self-cleaning oven part again. I can get the guy to tell you how he did it.
Posted on Oct 20, 2008
Door wont close - I have taken off hinges and they look ok. Is it possible that the hinge opening on the inner door has been stretched when I overextended the door with heavy turkey pot
It is very likely the control lock has been set on the oven. This means the door latch is unable to enagage with the oven lock. If you have turned off the power at the circuit breaker and there is no change, then you may try the Cancel button on the oven pad. Might be helful if you can provide the full model number of the oven.
Oct 09, 2012 | KitchenAid 24 in. Built-In Superba Series...
Oven door locked
put back in clean then cancle
May 25, 2010 | Zanussi ZBF360X Electric Single Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
How do i remove the oven door
To remove the door download the manual on link below and go to bottom of page 28. It will tell you how to remove.
Dec 23, 2009 | KitchenAid KESK901SSS Electric Kitchen...
The door is locked
Put the unit back into a clean cycle, wait 2 minutes and then push cancel, the door should unlock
Jan 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Nov 22, 2007 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven problem
plug the oven back in. open the door all the wat. there should be a door light switch in the upper right hand corner. if the oven is all the way cool you should be able to hold down the door switch for a min or 2 after you plug it back in and the lock will go back to normal position
Nov 21, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESK901SSS Electric Kitchen Range Logo
385 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
