Question about Microsoft Windows Vista Home Basic Edition for PC
I am trying to get my compter back to its factory settings i dont want anything else on it how would i do that
  • 156 Answers
Dear Jonny,
when you start your computer, press F8 while windows loads.
in next dialogue box click on NO to goto restore point, revert back to the restore point of the earliest date. You will get your factory setting back. if it does not work simply format get original version of windows format hard disk and reinstall windows.
Good Luck
Zulfikar Ali
ali_zulfikar@yahoo.com
Posted on Apr 30, 2010
  • ali_zulfikar
    ali_zulfikar Apr 30, 2010
    Pl revert back to me, if having any problem.
I bought a company compter and it does not allow me to do anything to the control panel, how do i reset to factory setting?
antoniogmart,
Unfortunately, the Optiplex 740 did not ship with a Factory Restore Partition. You will need to manually reinstall Windows, Drivers and Software. Below are links to provide you with information on installing Windows XP as well as the drivers download page.
How to Manually Reinstall Windows XP
How to Manually Reinstall Windows Vista
Drivers Download Page for Optiplex 740
Drivers Install Order and Help
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 23, 2013 | Dell OptiPlex 740 PC Desktop
Trying to unlock my acer a500, but cant...how do i set it back to factory settings
Dear Friend,
Try this:
1. Switch off
2. Press Vol-up + Power
3. If display goes on: Release power but hold vol-up
3. Toggle Lock switch (On>Off>On>Off)
Screen will display:
Erasing Userdata..
Erasing Cache..
Nov 28, 2011 | Acer Iconia Tab A50010S32u Notebook
I have a 1996 3.8 liter camaro. I was driving my car down the road when the gages started jumping and i found out that problem it was the battery and aldernater well after i changed them problems i have...
Hmmm, a puzzle.
The only way to disarm these alarms is with
the factory remote or turning on the ignition.
To turn off the factory alarm.
Ok, do you have the remotes?
If so, let's ID the system.
Go to www.KEYLESSRIDE.com & use th fcc #s
on the back of it.
If not try this:
Programming Factory Security on GM Cars and Trucks
Instructions for programming the GM factory security systems that do NOT
disarm from the driver's door key cylinder. This programming is for the
cars and trucks listed below.
96+ Camaro
96+ Firebird
99+ GM Trucks
99+ GM Sport Utility Vehicles
Step #1 Turn the ignition on then off.
Step #2 Remove the radio fuse only (not the fuse that says acc/radio).
Step #3 Turn the key to the accessory position. When you do this you
will get two chirps from the door buzzer. Should you hear only
one chirp, your vehicle does not have factory security and these
instructions do not apply. You need to hear two chirps.
Step #4 Press the unlock switch on the door. This will give 1-4 chirps
depending on the program step. Continue pressing the unlock
switch until you get to the desired chirp setting.
1 Chirp - Security off
2 Chirps - Remote Only
3 Chirps - Factory Setting
4 Chirps - Passive Arming
Step #5 Turn the ignition off.
Step #6 Put radio fuse back in.
Jul 03, 2011 | 1996 Chevrolet Camaro
I have a lenovo y 430 laptop and i want to restore it to factory setting. So I start with the laptop switched off. I click on the OKR button. My laptop just boots up as normal. Once it is on, I press the...
1. Turn off your compter.
2. Look for theOne Key Recovery button on your PC. It's near the power button.
3. Press the OKR button, wait until your computer turns on.
4. After Windows loading files you'll be routed on Lenovo One Key Rescue System.
5. Select One Key Recovery then, select restore from Intial back up.
Usually it will take 20-30 minutes for the whole process to be done. Once it's finish just reboot your computer.
If this fails, then call them.
http://www.lenovo.com/planetwide/select/selector.html
May 13, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
Computer doesn't recognize Sansa; Sansa not boot up
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
ALSO:
Download the driver to your compter while you are at the SanDisk website
Oct 01, 2009 | SanDisk Sansa e260 MP3 Player
I cannot hear calls but they can hear me
Not much to tell you other than putting the factory software back on it. Thats the chance you take when you flash any phone.
Sep 21, 2009 | Palm Treo 500 Centro
I dont know how to delete all the contacts
You could reset everything back to factory settings if your starting from scratch. Go into settings and find 'master reset', as long as your sister hasn't changed the phones default lock code when prompted for phone code enter, '00000' or '00000000' one of these is default. Then phone will turn off and reboot and will be as fresh as the day it was first purchased.
CAUTION: if there is anything you dont want to erase DONT DO THIS as it will erase everything back to factory default!
Apr 23, 2009 | Cell Phones
I dont know what to do to receive my E mail
http://mail.google.com/support/bin/topic.py?hl=en&topic=12805 If this link can not help you solve your problem if you tell me what kind of computer you have and what you are using to try and get you email I can give you more specific advice.
Mar 20, 2009 | Google Computers & Internet
Help me psp problem
i dont really understand what the deal is, but try resetting the console to factory settings. go to settings, system settings, restore to factory...
Sep 20, 2008 | Sony PlayStation Portable (PSP) Console
Microsoft Windows Vista Home Basic Edition for PC Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
