Question about Brother MFC-8440 All-In-One Laser Printer
Had no problem with envelopes for three years until two weeks ago. Now I must turn the envelope the opposite direction as before, and in the first printing the address is printed at the top of the envelope. If I print it a second time it prints correctly. If I print a third time it prints incorrectly. I also have problems with an envelope-sized form (PDF) and have to rotate the form 180 degrees to make it print correctly.
    Scholar:
  • 118 Answers
Whatever system you're using, check the envelope settings information in the program your using, this might solve your answer. or, go to the printer setup page and check to see if you have options for printing envelopes. hope this helps.
Posted on Apr 29, 2010
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
The Fuser is getting HOT. Error code 50.9 appears on our HP 3600N
i have a machine just like that it is normal that the fuser gets hot is a laser machine, and the part with the envelope the tracks for the paper might be worn out you said that you use it a lot check that or clean the tracks
May 26, 2009 | HP Color LaserJet 2600n Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Printing card envelopes
It sounds like you may have a size mismatch in the settings. Please refer to this link for information and the settings that you need to verify. You should be able to refer to the packaging for the envelope size to select.
Hope this helps. Please rate this information.
Thanks
Nov 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Envelopes all come out of the printer wrinkled
Open the back of the printer. You will see 2 little blue levers on either side. Put them in the opposite direction, that is, if they are up, snap them down. I dont know the mechanics of this, but it worked for me.
Nov 01, 2008 | Brother HL-5240 Laser Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Trouble printing envelopes
Instead of Word 2000 use Corel Draw for printing invelope. Because there are too many options for placing your text at desired position.
Feb 06, 2007 | Canon imageRUNNER 4570 Copier
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Brother MFC-8440 All-In-One Laser Printer Logo
346 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
