Question about JBL GTO937 Car Speaker
JBL GT 0937 BASS PROBLEM- BLURRING SOUND - JBL GTO937 Car Speaker
Disturbance while increasing bass in JBL SPYRO
I have a similar problem. You need to open your subwoofer and check if the subwoofers cone cloth is torn. If it's torn you can recone the subwoofer and it will work fine. There are solutions online to fix the cloth using regular synthetic mix cloth but i don't know if it works. Try removing the cloth to see if it sounds better.
Jun 03, 2013 | JBL Spyro Computer Speakers
I have the QSC PLX3602 connect from dbx pa as bridge mono to the sub woofer jbl mrx518. It works well. But now when I change it as stereo to the main jbl mrx515, I only hear the bass sound, no more...
I don't think that there's anything wrong with the amp.
I'll think you're using a x-over, connected to the low-output.
Just a shot,
Gerard
May 10, 2011 | QSC PLX3602
I just bought a jbl sub150 surround sound. my question is does it need a recevier to work or do the little speakers plug into back of sub
Didn't it come with a manual?
Of course it needs external electronics to provide sound sources, controls, bass management AND amplification for the other speakers. It's just a sub.
Mar 21, 2011 | JBL Venue SUB10 Subwoofer
I have lost my serial no of Adobe Illustrator Cs2
>To install illustrator use key: 1034-1340-5003-7121-5803-5483
>Then chose the activate by telephone option and was given the request code:
5059 - 0493 - 2899 - 9049 - 2737 - 6085 - 6054
>The generated response code is: 9657 0937 4948 4768 4053
this doesn't activate illustrator...
>However it successfully activates illustrator if you reverse the order of the sequence of numbers in the generated response code....
i.e.
4053 4768 4948 0937 9657
Please vote if this helps.
Jan 12, 2011 | Computers & Internet
Bass level remote.
sound like a fault in the remote but try turnin the gain on the amp down a bit first
Jun 04, 2010 | JBL GTO14001 Car Amp
Amplifiers GT Series GT5-A604 ........explain settings
the amp probably has a x-over knob, a bass boost knob, and an eq knob. the eq is probably an internal crossover switch that will take the output from either high range (tweeters) or full range (6x9s) or low pass (subs) leave it on low pass. the bass boost however, will add distortion if turned up too high. its not noticable in the car, actually it sounds louder in the car but if you open the trunk and listen, you can tell its distorted bass and actually frying your speakers. the x-over knob is used to tune the frequency at which the amp stops pushing out bass tones. if you like rock music loud, turn it up higher, if you like low deep rap bass, turn it lower. keeping it too high might give you bad sound from either type though. ALSO THE GAIN OR LEVEL.IT IS NOT TO MAKE YOUR SUBS LOUDER IT WILL BLOW THEM .the gain is used to set your amp to your head unit which there is a procedure to do it.
Jun 15, 2009 | JBL GT5A604E 4-way Car Amplifier
Friend gave me a jbl surround system to go with my 52" sony hd tv. It has four speakers. three sat 20 and one bass 20. going to a rca stva 3970 receiver. didn't have instructions to go with it.
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | JBL 5.1-Channel Home Theater Speaker...
Car Audio & Video Logo
793 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
