Question about GoVideo Go Video DVD/VCR Combo
The DVD says "No Disc" when a disc in in the drive.
Not able to watch DVDs because the drive seems to be faulty and can't read when a disc has been inserted.
  • 140 Answers
The laser len is not working anymore.and doesnt read the disc
Posted on Apr 29, 2010
DVD WELL NOT READ DVD
Hi Alan, seems like your dvd player must NOT be region free, The link below is a short YouTube video showing how to set your dvd player to region free for FREE, The site is (your movie finder. Com) Also there's videos down the right side of the link that may help as well....... CHEERS..
https://www.youtube.com/watch?v=7LhQE0EPxqs Multi Region Codes for DVD Players
Apr 29, 2016 | Samsung DVD-VR357 Tunerless DVD Recorder...
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
I have a SD M1502 DVD-ROM drive. it can read CD's just fine, but it can only read SOME DVDs. example: im watching an anime series, store bought, but when i get to Disc 4 the drive cant read it. the DVDs...
There are a couple of things to look at: First of all does your computer have software to read copy-
protected DVD's. Second if this anime set of DVD's is imported from Japan it might not be compatible with players from the US. If you look on the Internet you can find patches for your DVD player software to read foreign DVD's. Check out VLC and libdvdcss.
May 03, 2011 | Toshiba SD M1502 Internal DVD Drive
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Oct 22, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Will not read DVD discs.
It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
A dirty lens can read CD but not DVD.
Tru first using a lens cleaner like this ones:
If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
You can order the lens pickup from factory and replace it.
Sep 02, 2008 | LG Computers & Internet
Dvd rom problems with my macbook
Does the computer immediately return the discs after they're inserted or do you have to manually eject them? If it's trying to read the discs then there could be a problem with the type of disc. However if it just ejects the disc immediately, there could be a recognition problem. So, if your computer doesn't recognize that a disc is in the drive, you can check several things. 1. Check to see that the computer actually reads DVDs. To do this, open the System Profiler in the Utilities folder. Click on ATA/Devices and Volumes/Disc Burning. Those are three different options but each will tell you if the drive actually does run DVDs. If it shows DVDRW or DVD, but if it only shows CD or CD-RW, then it won't play a DVD. 2. If it shows that it accepts DVDs through the System Profiler, then you'll need to check to see if the actual drive is attached. You can open your computer through the battery with a screw driver. Once open, you'll need to check the connecting cable to the drive. If it's attached properly/securely, you may need to take it to a technician. The drive me be malfunctioning and need professional repair.
Feb 19, 2008 | Apple MacBook Pro Laptop Computer with...
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
DVD problem
Have you tried several DVDs? Maybe it doesn't read some types of DVDs.
Mar 21, 2007 | Dell Dimension 4600 PC Desktop
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
GoVideo Go Video DVD/VCR Combo Logo
110 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
