Question about Air Tools & Compressors
I''m trying to remove a starter motor on my 1994 doge dakota truck.i have one bolt offbut the other will not budge.is there a special tool that i need to remove starter motor
  • billyandpat Apr 29, 2010
    yes iam goimg to let wd40 try to loosing bolt up
  • 15,935 Answers
No special tools necessary. It is likely rusted in place.
Spray with penetrant and allow to soak in.
Loosen the alternator adjusting bolt and swing the alternator in toward the engine. Disengage the alternator drive belt.
THanks!!
Posted on Apr 29, 2010
I can't get mthe starter out of my 1994 Z-26 beretta. It has a 4 cylinder motor. I took one big bolt out and the other big bolt was already out missinge bolts.Why won't the starter budge?
Note the picture. Is this what you have? What about the rear bracket, #1? Maybe it's hung up on the flywheel? Did you try tapping on the starter motor with a big hammer, to see if it would come loose? I'm not saying beat it to *****.
May 21, 2017 | Cars & Trucks
Fan pulley nut won't budge
it may be reverse threaded
Aug 11, 2012 | BMW Cars & Trucks
How do I change the starter on a 1994 oldsmobile Cutlass Ciera
Since its right there at the front of the motor, you really only need a simple ratchet and appropriate sized socket or box wrench to get it loose, but you want to make sure that you label the wires as to remember which terminals they go on;if not reattached correctly, there will be electrical problems with gauges and overall car operations...
Jun 23, 2012 | 1994 Oldsmobile Cutlass Ciera
How hard is it to change the starter? Can it be done with standard tools and one the ground without ramps? Thanks.
Since the motor is located at a lower point in the engine it will require that you JACK up the vehicle so that you can access the starter motor. It is important that you must be able to work in such postion with the tools to remove the two bolts that are bolted on the starter. You will need socket spanners/ box tools to remove the bolts.
Jul 08, 2011 | 1994 Nissan Pickup
I need to replace the starter in my 1998 dodge dakota. Anything special I need to be concerned about?
just disconnect ur battery. remove 2 starter bolts, then disconnect wires attached to starter. install in reverse order.
May 23, 2010 | 1998 Dodge Dakota
I need to fix a starter on my car
3.1L Engine
Besides regular hand tools, a special oil pressure sensor socket will be necessary to complete this operation.
  1. Disconnect the negative battery cable.
  2. Raise and support the vehicle safely.
  3. Remove the A/C compressor brace (if equipped).
  4. Extract the wiring harness from the retainer and position it out of the way.
  5. Remove the cover from the starter wiring.
  6. Remove the outer nut and disengage the wiring from the starter solenoid.
  7. Disconnect the electrical connector from the oil pressure gauge sensor.
  8. Using the special socket, remove the oil pressure gauge sensor.
  9. Unbolt the starter from the engine. Retain any shims.
To install:
  1. Install the starter to the engine, reuse any shims that were removed. Tighten to 32 ft. lbs. (43 Nm).
  2. Connect the wiring to the solenoid and install the outer nut.
  3. Place the cover over the starter wiring.
  4. Replace the oil pressure gauge sensor using the special socket.
  5. Plug the electrical connector onto the sensor.
  6. Mount the harness to the retainer.
  7. Install the A/C compressor brace (if equipped).
  8. Lower the vehicle.
  9. Connect the negative battery cable.
3.4L Engine
This starter is serviced only as a complete unit.
  3. Disconnect the electrical connectors at the starter.
  4. Remove the converter cover.
  5. Remove the starter motor mounting bolts, and remove the starter.
To install:
  1. Install the starter motor to the engine using the mounting bolts. Torque the bolts to 35 ft. lbs. (47 Nm).
  2. Install the converter cover.
  3. Reconnect the electrical connections to the starter.
  4. Lower the vehicle.
  5. Connect the negative battery cable.
3.8L Engine
  3. Remove the cover from the starter wiring.
  4. Remove the outer nut and wiring from the starter solenoid.
  5. Remove the screws retaining the wiring harness clips and position the harness out of the way.
  6. Take out the screw that retains the plastic flywheel cover and remove the cover from the vehicle.
  7. Remove the bolts retaining the starter to the engine block, and remove the starter from the vehicle.
To install
  1. Install the starter and tighten the bolts to 32 ft. lbs. (43 Nm).
  2. Install the plastic flywheel cover and screw
  3. Reposition the wiring harness, and screw in the retaining harness clips.
  1. Reconnect the wiring to the solenoid and install the outer nut.
  2. Replace the cover over the starter wiring.
  3. Lower the vehicle.
  4. Connect the negative battery cable.
Jan 19, 2010 | 1994 Pontiac Trans Sport
93 or 94 Dakota Transmission
look at the starter bolting the location on bell housing differ depending where manufac...
plus start counting splines on the shafts..
May 07, 2009 | 1994 Dodge Dakota Club Cab
Trying to remove the starter on a 1991 SaturnSL
no there is not a special tool need more info go to collisionrepairadvice.com for more
1991 Saturn SL L4-1.9L DOHC VIN 7 Vehicle Level a_003366.gif Starting and Charging a_003366.gif Starting System a_003366.gif Starter Motor arrow1.gif Service and Repair arrow2.gif blnk_spc.gif Service and Repair Notes
  1. Disconnect battery ground cable.
  2. Remove air inlet tube and fresh air hose, on DOHC models, lift resonator upward to disengage from engine support bracket.
  3. Remove upper starter attaching bolt through access hole near intake manifold support bracket.
  4. Raise and support vehicle.
  5. Using suitable pliers, remove starter shield pin, then lift shield upward to release from solenoid.
  6. Disconnect starter electrical connectors and position aside.
  7. Remove lower starter attaching bolt.
  8. Remove rear starter support bracket attaching bolt.
  9. Rotate starter until bracket clears axle shaft support bracket, pull rearward toward lefthand side of vehicle to remove.
  10. Reverse procedure to install. Torque starter attaching bolts to 26 ft. lbs., starter bracket bolts to 22 ft. lbs. and starter solenoid terminal to 3 ft. lbs.
Apr 11, 2009 | 1991 Saturn SL1
How remove front brake rotors from 1990 4Runner w/ auto lock hubs?
you might try Google, '95 4runner hub r&r. I did it for the starter in my daughter's neon and found step by step instructions. good luck, John
Nov 07, 2008 | 1995 Toyota 4Runner
Air Tools & Compressors Logo
63 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
