Question about Samsung CLP-315W Laser Color Printer
My Samsung CLP 310 won't come out of sleep mode preventing me from printing. How do I wake it up. There's nothing in the manual or in Samsung's troubleshooting guide.
I finally got my CLP325W waking up correctly from sleep, but I made a few changes at once and don't know for certain which one (or combination) worked. Here are my changes:
1. disabled the USB port. (I had originally set up the printer via this port).
2. disabled IPv6 support.
3. disabled the dynamic DNS registration.
4. enabled telnet (though I doubt this had any effect).
My setup uses a static ip address that is outside the range of the dynamic addresses my router assigns and I use a mac filter on my router without any problems.
Posted on Nov 23, 2011
  • Daniel Schler
    Daniel Schler Feb 18, 2014
    For me Disabling IPv6 did it.
I had faced the same problem, after the printer switched into the sleep mode, I could't wake him up. So I have checked why, and I could find a solution so far, then I have deactivated my mac address filter list of my router, and see it works, hmm, so I have checked the WIFI settings again and found the BSSID mac address, so I have added this address to my mac filtered list, and see bingo it works fine !
Hope hat helps, I found another solution which means when you have spaces in your SSID the printer can't wake up as well, but I can't confirm this problem.
Jan
Posted on Jan 01, 2011
  • 1 more comment
  • johnzurich Jan 02, 2011
    Unfortunately the problem got not solved. I have figured out, when the printer switched into the sleep mode, I can't still reach the printer. Ok, it seems not a printer problem, because when I restart my WIFI router (an Apple Airport extreme) the printer is reachable !! Therefore I have checked the router settings and found the parameter "WPA group key timeout", the default value is "1 hour", so I have increased the value to "1 day".
  • nosiele May 31, 2011
    I experience the same problem on the CLP 325W when on Wireless network.
    I can do one of the following:
    1. Restart the router and then it comes available...
    2. Wait for 10 minutes and then suddenly it comes online and the spooler will print...
    Annoying to have to wait, but at least it works in between.
    I upgraded to latest firmware too, but no change...
  • kurt_oj
    kurt_oj Feb 11, 2012
    The problem you have is the wifi router. set the security to WPA mode = Auto (wpa & wpa2) i had the same problem and used wpa2, and the printer wouldnt wake up. when using auto mode problem solved...
How can I wake up my printer which keeps going into the sleeping mode?
Rather than pressing the "Big Red Button", try just pressing the power button, once, for like, a second. Depending on your printer's age, you may just need a new one.
A few good printers are listed below
Feb 17, 2015 | Samsung Colour Laser CLP-320
Printer problem with OS X 10.9 Mavericks
THE SAMSUNG CLP-310 is fully supported by Mac OS X 10.9 Mavericks. The printer driver (like all nowadays) is supplied by Apple not the manufacturer. If you installed drivers/software from a disk, you need to put that disk back in and run the uninstaller. Be sure the printer is removed from the printer list in the Printing system prerefernce pane and then unplug and replug in the printer. If it does not show up automatically you may need to add it manually in the system preferences window (no big deal.)
Nov 22, 2013 | Samsung CLP-310 Series
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
CLP-315 - CLP-315 Laser Printer: Printer says it is online and ready to print. All ...
you may want to run a repair on the printer driver. by going to windows START -> all programs -> Samsung CLP 310 -> Maintenece - > repair and follow the onscreen next till finish.
this could help some time when you swap USB cable or port or PCA main been replace or updated.
May 17, 2010 | Samsung CLP 315 Laser Printer
Samsung clp 310 printer regularly jams
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
May 14, 2010 | Samsung CLP 315 Laser Printer
Printer doens't like to print anytime
It sounds like this printer is not coming out of sleep mode. You need to change the settings so the printer do not go to sleep mode (power saving mode)
Aug 06, 2009 | Samsung CLP-300N Laser Printer
When trying to set up Samsung CLP 310 I cannot get the software loaded. Sony notebook VGN SR220J. Server works fine from 2 network connected PC's I've tried it from the disc and the loaction on the HD.
download latest drivers and install with printer unplugged...it will install software to c:\program files\samsung\ and then 2 more folders in you will get the drivers folder - add printer and just do have disk and browse to that folder.
Aug 01, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Greyed out duplex option Samsung CLP-310
does the printer have a duplex option,if yes should be able to print,check driver.if no,option does not allow you.
Jul 06, 2009 | Office Equipment & Supplies
How to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
Jun 21, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315W Laser Color Printer Logo
5,692 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
