Question about Samsung NC10-14GW Notebook
When i plug the mains power lead in, the screen goes white.
    Problem Solver:
  • 13 Answers
Check if the battery is locked properly in the back of the laptop there is a notch and make sure it is not on halfway , also go to bios by restarting and F2 the trn of the autobrightness off. If neither of this helps then contact the manufacturer if stil under waranty as it may be hardware problem.
Posted on Apr 29, 2010
Wireing diagram to reconnect cable wire power lead (cable)
If it's the main power cable
from a wall socket then get a qualified electrical contractor to do it do not try this yourself please.
Oct 13, 2014 | Abbaka White Knight 44AW Electric Dryer
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
My ipod touch will not go to the main screen. All I see is white. What do I do? I click the top and it goes black. And when I click it again it turns white and will not show the main screen. It was on the...
Welcome to Fixya
This problem is called the white screen of death. To solve this, you should press the Home button and the Power button together for about 30 - 40 seconds. This process is called hard reboot. You can also try to restore the factory settings by plugging the device to you computer and restore it using itunes.
Thanks!
Nov 06, 2010 | Apple iPod touch
While replacing the LCD screen on a cq60, I removed two plugs from the LAN card. What are they connected to? I lost them.
These plugs are connected to a black and a white (tan) wire. These wires lead through the hinges of the screen assembly and attach to metal clips at the top of the display under the bezel. These are the wireless antenna leads. The card itself will have the words main and aux. on it along with a small triangle that is either black or white, this is color coded to the proper wire at its connection.
Sep 05, 2010 | Compaq Presario CQ60-220US PC Laptop
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Printer won't turn on...is plugged in and has been printing well.
hi, have you tried checking, changing the fuse in the plug.
check the lead is fitted correct.
as for the fuse is the printer running of mains lead or just of the usb lead let me know, if its mains the unplug the lead that goes to your comp and then try it with just the power lead plugged in to see if that makes the differance.
Check the mains lead works try it on something else if you can if its running off only the usb lead then the lead may be at fault.
Let me know then i can assist you further ok
Nov 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
Plug red and white cables into woofer ports that are red/white
Plug purple lead into front of woofer to input port
green goes into accessory (green) port on back of computer
elbow shaped 2 prong leads go to speakers in back
DC power goes into front of woofer marked DC input
Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Second screen does not work
Make sure you have the both lead from the main unit to the second screen plugged in (Power and video lead - 3.5mm jack to red/white/yellow phono)
Also make sure the jack is plugged into the A/V OUT socket of the main unit and NOT the A/V IN.
Jan 21, 2008 | Philips PET708
Samsung NC10-14GW Notebook Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
