Question about Life Fitness 9500RHRT Recumbent Bike
Where can I get an electrical schematic diagram for a lifefitness 9500hr dovetail recumbent bike? Want to trace the heart rate wiring plus other areas.
  • 83 Answers
Click here then click on LC95RS-0109-04 Parts list and the wire schematic is on the last page.
Posted on Apr 29, 2010
Testimonial: "Thanks. Helps trace the wiring. Now to find the problem and fix it. "
Looking for owners manual online
Here is a link to the Life Fitness support page. You should be able to locate your manual there:
http://www.manualslib.com/brand/life-fitness/exercise-bike.html
Jul 17, 2015 | Life Fitness 9500HR Recumbent Bike...
Battery 9500hr
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
If the battery continues to fail, I would check the alternator brushes and see if they need to be replaced. Chances are they are worn and the battery is not being recharged sufficiently.
Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Feb 23, 2014 | Life Fitness 9500RHR Dove Tail Recumbent...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
The bike goes to Pause mode frequently throughout the workout. I have tested all the exercise modes and made sure my RPMs stay the same but it just flips to pause and then starts working again...
Star Trac Pro Upright Bike Owner's Manual - ManualsLib
www.manualslib.com > ... > Exercise Bike > Pro Upright Bike
Exercise Bike Star Trac Upright Sport Bike Owner's Manual. Stationary sport bike (28 pages) ... Pro Upright Bike Pro Recumbent Bike ' W N E R A N U A L..
Jan 20, 2011 | Star Trac Sport Recumbent Exercise Bike
Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Apr 17, 2010 | Life Fitness 9500RHRT Recumbent Bike
Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
Mar 15, 2010 | Exercise & Fitness
I have a lifefitness 9500hr that keeps burning resistors on the motor control board.
I am asuming you tested the drive motor, did any burning smell eminating from the motor? We do have a short in that board if that is still on your bench I would trace where those conponents are going to and use if you have a portable Dc power supply with voltage and current displays I would set power supply at a lower voltage ( 1v to 2v ) take grd lead to grd and use red for the purpose of isolating the short could be in the bank of IGBT's Caps shorted etc depending on location of damage.
Mar 02, 2010 | Life Fitness 9500RHRT Recumbent Bike
I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
Feb 18, 2010 | Exercise & Fitness
Precor C846 Recumbent Bike - heart monitor not working
You can test the HR grips to see if the wiring is good all the way from the contact grips to the upper board by doing a test with your meter. Get a meter that can test fuses and beeps if the fuse is good.
disconnect the 4 pin brown connector at the console board, on one side will be some metal contacts.
Touch one end of the meter lead to one wire and the other to the HR contact plate on the handlebar. try all the contact plates on the handle bar until it beeps, then move the lead to the next wire and repeat until all contact plates beep. It all of them beep then your wiring is ok and the problem is in the Heart Rate board in the console or the connection point on the board.
Let me know how it turns out.
Santafe
Apr 06, 2009 | Precor Exercise & Fitness
Heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
Mar 12, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9500RHRT Recumbent Bike Logo
796 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
