Ricoh Aficio SP C811DN Laser Printer Logo
Anonymous Posted on Apr 29, 2010
Ricoh SP C811DN error sc549
My office printer, a Ricoh SP C811DN color laserjet suddenly began showing an error message SC549. Please help resolve
Anonymous
Level 2:
Scholar:
  • Expert 118 Answers
  • Posted on Apr 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
118
Questions
0
Helped
38096
Points
237
Unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
1helpful
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
Error sc549
fuser encoder error
-replace Encoder Ferrite core switch - B2234240
-replace Photo interuppter - Horizontal 7mm AW020190
3helpful
2answers
My ricoh sp c811dn suddenly started displaying the
Here is a way to reset but make sure you follow the instructions correctly.
turn off machine
press online and escape buttons together whilst turning on machine,
when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN.
Turn off printer and wait ten secs then turn back on.
If only temp error this should reset and start up again, Good luck
1helpful
Error message
It's the fuser. You can try turning it off, wait 30 seconds, and turn it back on again.
If the problem continues, call a technician in to get the thermistor replaced.
It's a common error.
14helpful
2answers
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
