My SONY SDM-HS73 monitor screen keeps flashing ( it goes black then back to normal every 1-3 seconds ). The power light remains green but the screen keeps flashing. After I boot the computer the screen flashes really fast then after a few hours it slows down a bit, but still continues to flash. This is very annoying and can sometimes last a whole day. Is this something I can fix myself or will I have to get a new monitor ? Please help Thank you.
  • 11,361 Answers
Common problem in the 73/93 is poor soldering works in the Lamp assemblies. See pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
You should also inspect the inverter board also for loose connections.
Posted on Apr 29, 2010
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Sony sdm-hs73p LCD blacks out
Common problem in the HS73/93 is bad soldering works in the lamp assemblies, see my pictures here:
But look for bad caps (leaking/bulging top) first in the power supply section.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Sony SDM-HS73P 17" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Six years excellent service then the screen went black except during start-up the start-up screen flashed om and off, and remained black through the Windows start. The screen did flash on for a second on...
You may have failed backlight inverter circuits, caps failure in the power supply, or bad lamps. Here is the service manual: http://www.eserviceinfo.com/downloadsm/22184/SONY_SDM-HS73.html
You will need to open it up and take some voltage measurement in the power supply first to make that you do have correct DC voltage feeding the inverter PCBA.
Mar 25, 2010 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS73 problem
there may some spike(voltage goes above 1000v for few microsecond) come from electricity board
which may damaged colors ic you have to replace it and connect spike arrester before pc
Oct 29, 2008 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Oct 01, 2007 | Sony SDM-HS73P 17" LCD Monitor
Sony Monitor ... SOMEONE HELP, please!
Thanks for your response. I actually sent my monitor out to guy that does LCD repairs for cheap. He changed out the video board and did repairs similar to yours but still couldn't get the monitor to work. After some more testing, he found that one of the chips that contained Sony's proprietary firmware had gone bad and said there really was no way to replace the chip. It definitely seems like we had the same problem, so I thought this information may help. I'm sorry that you paid so much for repairs that didn't solve the problem.
May 14, 2007 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Computers & Internet Logo
279 people viewed this question
David Payne
David Payne
