Question about Thermador DWU244 Dishwasher
THermador dishwasher error code F
All of a sudden my dishwasher keeps running and there is no water and now it has an F code on the display. What does this mean and how do I fix it??
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
  • 3 Answers
SOURCE: lg dishwasher ld2120w is displaying
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Posted on Nov 07, 2010
SOURCE: Error code E4 is on
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Posted on Dec 14, 2010
What does the thermador dishwasher dwhd640jfp error code e:21 mean?
E21 Circulating pump blocked.
A blockage between the motor or the pump resulting in insufficient water flow.
Feb 22, 2015 | Thermador Dishwashers
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
What would be the main reason a thermador dishwasher model #'DWHD64EP would keep water in the bottom?
It is usually caused from food scraps that get caught in the drain filter. It is located on the bottom of the machine under the lower rack. It either pops out or unscrews.
Good Luck
Jan 04, 2011 | Thermador DWHD64EP Built-in Dishwasher
Takes more than 2 hours to complete a one hour cycle. Will sit on "1" minute left for the last 45-60 mins. If the door is opened during this long one minute the washer still has water in it and will...
Welcome to fixya.
**What I`m about to share applies to Almost all Electronic control B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it.
I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line.
Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle and displays "1" ( 1 is an error code for not heating ) or takes an extremely long time, is the control has detected a heating error.
Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The error likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
This is why it runs really long/forever, display`s "1" unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The burnt solder joint will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
You can also enter a test to check for proper amperage via the use of an ammeter as such...
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
Macmarkus :)
Aug 30, 2010 | Bosch SHU5315UC Dishwasher
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Feb 15, 2009 | Thermador DWU244 Dishwasher
Thermador DWU244 Dishwasher Logo
298 people viewed this question
Top Thermador Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
DROPNDEAL
DROPNDEAL
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
