Question about Savin 8035e Copier
How do you reset the savin 8035 sc542 code after thermistor is replaced?
    Problem Solver:
  • 11 Answers
Enter service mode....and look for the service call reset .it's in mode or program,you just press reset and restart the machine Entering and Exiting SP mode " 1. Press the Clear Mode key. 2. Use the keypad to enter “107”. 3. Hold down Clear/Stop for at least 3 seconds. 4. Enter the Service Mode.
Posted on Jul 12, 2010
  • 23 Answers
Press the yellow button ( reset button ) then press 107 then press and hold the red button (stop button ) for about 3 sconds until the display changes. Touch copier on the display screen. Now turn the copier off using the on off switch on the left front side of the copier. If the cold comes back the Thermostat in the fuser is most likely tripped and would need to be replaced.
Posted on May 14, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
SC542 Error
fuser temp warm up error. Open thermostat or defective thermistor. also open fuser lamp
Apr 02, 2013 | Savin Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Are there availability issues for parts for the Savin 8035? We have one in our office which is under a service agreement and have been told it will be 2 weeks for a part. Is that realistic? We're being...
Try going through the Ricoh website, the product code is B291. The Savin 8035e is the same as Ricoh Aficio MP 3500, Lanier LD335 and Gestetner DSm735e. Hope this helps
Jul 18, 2011 | Savin 8035e Copier
I have a savin 8025e and it is giving me an error code sc542 what is the fix for this
SC542 = Fuser warm-up error.
Possible causes are:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective fusing lamp
• Defective power supply unit
You can try resetting the code using this sequence...
Press the Yellow button, 1,0,7, Press & hold red stop button until machine beeps and the display changes. Then turn the copier off and back on.
Hopefully the machine will now come to ready. OIf not the likely cause is either ther thermal fuse or heater lamp.
Hope this helps
Feb 03, 2011 | Ricoh Aficio MP 161 Black and White Copier
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin 2522 sc542 error code
It's a fusing warm up error. The temperature isn't reaching the right rate within 20 seconds.
There isn't a reset procedure due to safety reasons. If you replace the thermistor, it should go away.
Mar 16, 2009 | Office Equipment & Supplies
Savin 8035e Copier Logo
1,053 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
