Question about OKIFAX 5650 Plain Paper LED Fax
Communication error keep getting communication error when faxing
Fax won't transmit long distance faxes
Your long distance access is being blocked by the telephone company for some reason.
Apr 07, 2010 | Brother MFC-7220 Plain Paper Laser Fax
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
Epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
What does COM-E mean when we try to send fax's and the transmissions has this written on it instead of OK.
It means "Communication Error".
The result might be twofold:
- the fax didn't reach it's destination because of communications error (any kind)
- the fax did reach it's destination, but part of it may be unreadable or distorted, or some pages of a multi-page fax did not go through.
In many cases, what the device perceives as an erroneous transmission, is perfectly readable by a human. Therefore it's good to call the recipient and ask if the fax is readable and if all the pages were received.
Nov 13, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Artisan 800 fax keeps getting communication error 0402
When I went to my epson account noticed that I had a toll free number after hours to call and talked to them and turns out one of the fax settings ECM should of been Off and everything works fine.
Oct 07, 2009 | Epson Stylus Multifunction Printer/...
I am trying to send a Fax but keep getting a communications error
Vonage is a DIGITAL phone service. ALL fax machines are analog devices. You need a plain old telephone line.
Jul 22, 2009 | HP LaserJet 3050 Printer
Fax machine communication error 43 on kx-f750
communication error 43 is error of telephone line.there is some distarstion in telephone line.some noise in line .due to this it is facing problem.just clear ur line .or check with an other line.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
Apr 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
OKIFAX 5650 Plain Paper LED Fax Logo
63 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
