Question about Water Heaters
I have a Baxi Combi 80 eco...the radiators work fine but I can NOT get any HOT water from the taps..??
5 Suggested Answers
SOURCE: baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Posted on Nov 02, 2008
  • 3 Answers
SOURCE: combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Posted on Dec 30, 2008
zeusfaber
  • 247 Answers
SOURCE: Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Posted on Feb 03, 2009
mrhotandcold
  • 248 Answers
SOURCE: no hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Posted on Oct 12, 2009
I have a baxi combi he 80 plus and after more than ten visits from our local housing association plumber it still when starting up clicks and clicks for 4 to 5 secs, repeating itself until there is a large...
Well its not right should not lighting with a bang or boom Its not lighting on the first stage pilot only and it sounds like you are getting full gas . In 10 visits I would ask them to call B gas or Baxi to fix this as this guy cannot .
Dec 29, 2017 | Water Water Heaters
Radiators hot no hot water. Luke warm for a bit. Then back cold. Setting is past 'eco' just moved in not used to combi but surely this isn't right
check the diverter valve. look to see if when hot water turned on the small electrical switch at the end operates. If not then a ned valve or diaphragm
Apr 10, 2015 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
No hot water...can any1 help i have a baxi combi 80e
Oct 12, 2009 | Water Heaters
I have a chaffaeux combi 80/100 no hot water
sounds like diaphagm valve or micro switch best of luck
May 06, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
A.
Feb 03, 2009 | ACCO Brands Water Heaters
Combi cutting out and overheating
Dec 22, 2008 | Water Heaters
Baxi combi boiler 80e safty thermostat light on
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
63 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
