Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My door doesn't seal/catch when closing. Machine
My door doesn't seal/catch when closing. Machine still works if something pushed against the door. Is the catch broken? Is there anything I can do to repair it, or do I need a technician and what is the going rate?
Many thanks,
M. Berlagoski
  • 15 Answers
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Posted on Apr 29, 2010
Testimonial: "Thank you , we will try this."
Broken catch kl75cm
HI THERE,MY CATCH HAS GONE TOO,WHAT I DO IS GET A LENGTH OF WOOD,SAY 2 BY 1 OR 2 BY 2,PUT ONE END ON MACHINE DOOR HANDLE,AND WEDGE THE OTHER END AGAINST THE OPPOSITE WALL A LITTLE DAMP CLOTH AT BOTH ENDS OF WOOD WILL HELP AGAINST SLIIPPAGE.WORKS A TREAT.
ONE IM USING AT THE MO IS PLACE A STRONGBOX IN FRONT OF MACHINE NICE AND CLOSE,THEN PLACE A RATHER LARGE CONCRETE GARDEN GNOME ON BOX.ALSO WORKS EVERY TIME,I KID YOU NOT..GOOD LUCK...MARK IN SWANSEA
Mar 31, 2015 | Washing Machines
Sebring window
Look into window guide clips. These push the glass against the rubber
Oct 28, 2013 | Cars & Trucks
The soap dispenser does not open to let the detergent out during the wash cycle.
Sometimes if the tablet is not put in correctly it makes the door catch jam as the tablet is pushing against the door and not leting the catch move to open. try putting the tablet in then close the door then just flick the catch to open the door to see if it opens easy. if this dose not cure it then the door catch has moved or got loose behind the door cover. with the electricty off and plug removed you migh try taking the screws that hold the main door front on and then checking the plastic arms are all inline and move easy. the door catch works on a selonoid that throws open the catch, its unlikly that this has gone open curcuit but if this is not opperating i think you need to call an engineer.
Jan 20, 2010 | Whirlpool Dishwashers
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Mar 08, 2009 | Kenmore Kitchen Ranges
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lower door wont stay closed
I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
Jan 10, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Apr 07, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
574 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
