Question about Cameras
Having to format picture card evertime turned on Card not initialized
Once formatted each time, getting error message
"Write Error?
I don't know why I can't take picture?
Plug the camera into the usb cable or use a card reader and reformat thru your computer.
Posted on Jun 12, 2008
I viewed pictures on my computer and didn't upload them. When I placed my sdhc card back in my camera it gave me the error message "memory card error" and "card locked", however the...
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jul 15, 2011 | Cameras
I have a finepix S602Z and when i turn it on it comes up as card error this happens on different cards any ideas on how to correct this please
I suggest you take the batteries out and wait two minutes and reinsert them. Making sure that they are inserted correctly. If this doesn't work, try replacing the batteries with new ones.
If you formatted the memory card using your computer, or deleted images using your computer, you now need to Format the card with the CAMERA. One of the camera menus will have a Format command.
This is what FujiFilmUSA.com has to say about the Card Error:
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.
We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.
Feb 14, 2011 | Fuji FinePix S602 Zoom Digital Camera
I just purchased this camera and inserted a memory card. Now, when I try to take a picture, I get the 'card protected' error. How do I remove this error and take pictures?
Without knowing the make and model of this new camera I can only speculate on the problem however in my opinion you need to unlock the protected card I'm giving a diagram of an SD card here.
Slide this little switch to the top or towards the gold contacts.
Another thing you will need to do is format the memory card your camera may call this initialize.
Formatting a memory card makes it ready to accept information files from the camera. I hope you have your manual because without knowing the camera make and model i can only suggest where to look for this feature. Most often this function is in the set up menu, once the card is unlocked you need to find this format highlight it and press the okay button once done the camera will function properly as long as you have set the day date and time. Day date and time once set is held in the camera internal memory so you don't have to input the information each time you turn the camera off and back on again. Happy New Year
Dec 31, 2010 | Cameras
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
My xd-picturecard is not working in camera saying that card is not initialized My memory card worked fine the first time I took pictures with it, but after taking it out to upload them and then replacing...
see if there is a format highlight in menu of camera-this will format card to camera and should make it compatible-format will delete all data from card!
May 21, 2008 | Fuji Finepix F50FD Digital Camera
Fuji Finepix XD card was being used last night
Jan 01, 2008 | Fuji FinePix A345 Digital Camera
I had a similar issue with an XD card in my Fuji FinePix S3000.
I had used the several times for a couple of years without problem.
The issue appeared right after dowloading pictures from the card inserted in my notebooks' card reader - an operation I have done several times in the same notebook without any problem.
I have fixed the issue going to Menu, Option, SetUp, Format and choosed OK.
Deleted all the pictures (make a copy before if the card is readable in the pc as it was my case) but made the card readable again.
Nov 25, 2006 | Fuji FinePix S602 Zoom Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
