Question about Dell 966 All-In-One InkJet Printer
Changing ink cartridge in dell photo 966
Cant find where to chg cartridge
  • 4 more comments
  • Anonymous Apr 25, 2008
    this is my first time changing the ink, what do i do?
  • ritapope Aug 26, 2008
    how do I open the dell printer to change the ink cartridge?
  • Anonymous Sep 26, 2008
    i can't find where the ink cartiridge is so some1 needs to tell me where it is!
    this is my first time changing it so i need help
  • Anonymous Mar 02, 2009
    i dont know how to change my ink cartridge
  • yevonne1121 Mar 09, 2009
    my printer giving cartridge stall msg. whatt should I do?
  • joannms2000 May 12, 2009
    I don't know where to replace the ink cartridge on my printer.
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Posted on May 01, 2008
I am getting a message on my printer that says cartlige stall. How do I fix this. There is no blockage, no paper jam or out of ink. Cannot figure it out.
I have turned it off and back on, I have unhooked it and hooked it back up and nothing happens but that notice on my screen that there is a stall cartlige. Please help me.
Posted on Oct 30, 2008
  • marivic May 25, 2013
    same prob...how did u fix this Manyminds?
SOURCE:
Low ink message on dell 966 print after puting in new cartridge.
check to make sure the ink holes on the printer aren't clogged than run a printer cartridge report and see what it says sometimes depending what it is it might say on there! hope this helps
Oct 01, 2013 | Epson Stylus Photo R320 InkJet Printer
My dell photo 966 says'left cartridge missing Insert black or photo cartridge'.I've put in a new cartridge but I still get the same message.
the contact that detects the left cartridge may be dirty or not functioning at all. clean it with cotton and 100\% isopropyl alchohol then reinsert the cartridge. if it still doesn't work, it must be replaced.
Nov 06, 2009 | Dell 966 All-In-One InkJet Printer
I can't locate the cartridge on the dell photo 966 all-in-one. HELP
Ok
Be sure the power cord is in place. and the power is turned on. Next lift the lid and give it time and the ink cartridge will come to the center or left side so you can change them.
Hope this is helpfull to you. Sawdust46
Aug 19, 2009 | Dell 966 All-In-One InkJet Printer
Dell Photo 966 Ink Cartridge Keeps Gumming up. Cleaning Cartridges doesn't help. Wipe cartridge off and maybe it works for one or two pages before quality goes down. Replaced cartridges but still have same...
Since you already replaced the cartridges there is a problem with the printer.The cartridge must have made the pinter bad.Now you have to take it to the Service Center.
Regards
Jun 18, 2009 | Dell 966 All-In-One InkJet Printer
Can't print color only black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY. hope this helps , AJ
May 18, 2009 | Dell 966 All-In-One InkJet Printer
Refilled Ink Cartridge on Dell 966 all-in-one,how do i reset it?
I had this same printer but never was able to reset it. It has some type of sensor on it. That will not let it reset. I was told to unplug it from the computer. Turn the printer off. Reboot the system and plug the USB connector back into it once the system is booted. You may also try to reinstall the printer driver. I also find out that when the printer software says that the ink is low, it really is not. So keep on printing. What I eventually had to do is get a HP. No problem with HP, I can get a refill and it works. Now that I am think about this. See if you can disable the ink monitoring option in the software.
I hope this helps.
Please rate.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 966 All in one printer
make sure sticker off ink as u put it in go download new drivers from dell.com for it they have big updates to fix that
Feb 21, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
1,999 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
