Question about Akai DVDP5851 DVD Player
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
With disc in and tray closed, 'loading' appears on LCD panel but nothing happens. Observed this this top cover removed. Disc does not spin-up.
Can hear a noise every few seconds as if something is trying to start-up.
  • 3 Answers
The lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Posted on Apr 29, 2010
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
Hello
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
WISH YOU A HAPPY PROSPEROUS 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | Televison & Video
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
In the middle of playback the picture suddenly
Lens of the disc player needs to be cleaned.
Jul 06, 2009 | Pioneer DV-410V-K DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd will not play
dvd player is bad...you must order a new one...i dont know if it is available...but if it's under warrantee..then they must replace it or or the tv itself
Jan 01, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai DVDP5851 DVD Player Logo
264 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
