Question about Sierra Land designer
Will not install on an xp machine
Sierra Land Design 6.0 will not install on an xp machine
I CAN`T FIND MY WINDOWS PRODUCT KEY
Posted on Apr 30, 2010
Is sierra easy family tree for windows 95/98 compatible with windows 7? I have no problem with windows xp.
It probably will not work on win 7
If it will install you can try to run in compatibility mode by right clicking on the install after installing and clicking troubleshooting compatibility and adjusting the settings in the new box that will pop up
Sep 17, 2011 | Sierra Generations Family Tree Liberty...
I can't install photoshop cs5.. ERROR 6 will always stop!what to do?
try to run it as administrator- it worked perfectly(sorry if i spelled it wrong- i'm not english) :)
Aug 02, 2011 | Adobe Photoshop CS5 Extended - complete...
I have had the 3d deck version for some time witch i ran on an older computer with windows xp but i cant install it on my windows 7 ??????
Have you tried to install it in WinXP compatibility mode? Right click on the install exe and then select properties at the bottom. Click on the Compatibility tab and then select Compatibility Mode and select run in XP mode.
Good luck
May 01, 2011 | Sierra 3D Deck 3.0
I have upgraded from XP professional to widows 7 now I cannot install my Print Artist grande suite. please help Lorraine
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties.
Select Compatibility tab and select the Windows XP version.
This should work but if it doesn't there is nothing you can do except complain to Sierra to make a fix for it.
goodluck
Apr 08, 2011 | Sierra Print Artist Platinum
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
I have Windows Vista and would like to load Disney & Friends
It's not compatible beyond XP / 2000 .
there is a work around : install a virtual version of a earlier version of Windows with
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Hope this can help .
Reagards ;
Feb 04, 2011 | Sierra Disney Print Creations Full Version...
How do you replace the atenna mast for 2005 sierra.
How do I install a new antenna on my GMC 05 2500 Sierra. I have to replace the base because it broke off. I've taken the dash off. But cannot seem to fish wire through the firewall.
Nov 26, 2010 | 2005 GMC Sierra
Had to redo computer and reinstall. PA 4. won't install.
I found a solution for installing Sierra Print Artist 4 on XP at this site
http://forum.oldversion.com/programs-support/5831-printartist-4-a.html I did it, works great!
Posting below, thanks to izzy_eckerslike :
"""There is a way to force your computer to load print artist 4
Click on display /settings & reduce colour quality to 16 bit & reduce your screen resolution to 800X600
Then insert the Printartist disk & select install, as before you will see the Sierra logo on your taskbar but it won't move or do anything.
Now put your screen settings back the way they were before & you should see the install screen jump off the taskbar so you can access it.
It will test your computer & tell you it fails as it can't recognise newer technology but ignore that & select 'install anyway' & all should be working"""
Jun 30, 2009 | Sierra Print Artist Platinum
Sierra Land designer Logo
153 people viewed this question
Top Sierra Computers & Internet Experts
Glenn
Glenn
Les Morrison
Les Morrison
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
