My botteles water cooler form comany "Simply Cool" is leaking as a result of a crack
    Top Expert:
  • Heating & Co... Master
  • 76,846 Answers
Not sure what u are asking here, if it is cracked the unit must be replaced.
Posted on Apr 29, 2010
I removed the oil filler cap and there was a cream substance around cap.what can cause this?
Moisture builds up after the engine cools down and mixes with oil residue. This is an emulsion of oil and water that is common in areas that have large temperature variations. If you're in a hot climate this should not happen unless you're getting water into the oil. I would change the oil, heat it up completely then change it again while it's at it's hottest. Not fun but comparatively cheaper than a new engine by far. Probably nothing to worry about if you live in large variations of temperature. Wipe it out with carb cleaner & make sure your air filter is clean.
Apr 09, 2015 | Cars & Trucks
My 1996 Nissan bluebird had all the cool system replaced but is still boils the temp says its cold i need help to find out why it boils over
Looks like you have a leaking head gasket or cracked head. You can buy a head gasket leak detector kit that will let you know if there is CO2 gas escaping through the radiator. I think that it is this gas leak that makes it look like your radiator is boiling.
Mar 23, 2015 | Nissan Bluebird Cars & Trucks
Where is the oil cooler located? Does it have a water jacket?
if you are referring to the oil cooler for an automatic transmission, then it will mostly be in the radiator bottom/side tank and uses coolant to cool the oil. They have a habit of cracking/leaking and putting red oil in the radiator or allowing coolant into the transmission. The fix for this is costly flushing of the engine system and transmission and a new radiator. I would consider an air cooled oil cooler as they are more efficient and not prone to coolant problems.. They are generally cheaper than a radiator as the inlet/out let pipes can be blocked off
Sep 10, 2014 | Cars & Trucks
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Water leaked into transmission and transmition oil into radiator
Your transmission cooler is cracked. Discontinue using that cooler immediately. Get some caps, cap off the cooler. Replace the cooler with an after unit vor about $80.00. Change the transmission fluid and engine coolant before you drive any further.
Sep 19, 2011 | 1996 Ford Explorer
Transmission is leaking from my 2008 ford escape. The VIN number does show that it was manufactured in Kansas, but because i am in Canada the recall did not include canadian owners.
What do you need? I would cantact Ford of Canada in back of owner manual with letter, not phone, if issue is the same. TEXT:
In some of the affected vehicles, the transmission fluid cooler may develop a crack in the tube below the right hand (RH) mounting bracket from thermal and vibration fatigue. This may lead to a small transmission fluid leak and possible rough / harsh shifts. Dealers are to inspect the transmission fluid cooler for a grommet and possible fluid leak below the RH mounting bracket. Based on the results of the inspection, dealers will perform one of the following service
actions:
INSPECTION
1. Using a suitable light, look through the radiator grille and inspect the transmission fluid cooler mounting bracket for a grommet behind the mounting bolt. See Figure 1 and Figure 2.
Inspection Result Service Action
Grommet present - No further action required
Grommet not present and transmission fluid cooler not leaking - Install transmission fluid cooler mounting bracket
Grommet not present and transmission fluid cooler leaking - Install new transmission fluid cooler.
actions:
INSPECTION
Grommet present No further action required
Grommet not present and transmission Install transmission fluid cooler mounting bracket
Grommet not present and transmission Install new transmission fluid cooler
fluid
May 24, 2011 | Ford Escape Cars & Trucks
After putting a new bottle onthe water cooler it leaked brand water max
Sometimes the bottles might have a crack in it which prevents the suction within the bottle and they drain out. Try another bottle, if you get the same result, you will have a leak in your holding tank. If it is less than 30 days old, take it back. If not, the parts and labor are not worth repairing...replacement is needed or more cost effective.
Mar 06, 2011 | Vacuums
Oil keeps getting in to the water
if thats the case you should have water in the oil also, that means you have a blown head gasket
Aug 09, 2009 | 2002 Ford SVT Focus
Resorvior water loss
Change the radiator cap !
Normally overlooked , And they remove the cap to attach pressure tester so it cant show as faulty when its not fitted.
Not all cracked heads smoke , But if it were a cracked head you would probably have water in the oil (looks like custard on the dip stick).
Hope this helps.
Cheers
George
Jul 03, 2009 | 2003 Mitsubishi Outlander
Water Dispenser hamilton Beach Water Cooler
my water cooler worked yesterday,today I get nothing from either the hot or cold water? Is this a simple fix or di I start with a new one?
Jun 02, 2008 | Hamilton Beach Water Cooler with Storage...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
