Question about Canon PIXMA MP130 All-In-One InkJet Printer
Servicing the, waste ink absorber, on a Canon printer
Thank you Otacon;
I will try following the step-by-step advice you provided. Step-by-step is the most effective way to teach me anything!
Thanks again; Herb
PS: I know this is not a real question but I needed to make this comment about the "servicing the, waste ink absorber, on a Canon printer" problem you helped me with. I am unfamiliar with how this site works. Probably need step-by-step instructions on that too.
While I'm at it; How can I get a hold of the CANON company for a new User Manual? There, that's my question!
Thanks yet again; Herb Eichner
  • herbofwar Mar 25, 2008
    Thanks for the Canon Support phone # but the link you provided to the manual was a dead end.
    Thanks again; Herbofwar
  • Canon Master
  • 525 Answers
......To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
I hope this help!
Posted on Jan 15, 2015
  • 758 Answers
Here's a link to all the manual for that device:
http://manualshark.org/p/canon-3/canon-pixma-mp130-301/
I hope this helps
Thank you
Computerrep
Posted on Mar 25, 2008
  • 3,037 Answers
This is the user manual
Canon Contact Information Main support number 1 800 828-4040
hope this helps
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    please don't forget to rate this solution
  • Benjamin Patri
    the link I gave was page one of the manual, you can view the other pages by clicking next or changing the internet address by changing the last number which is the page number
SOURCE:
Tip
How To Reset Ink Absorber Canon i550
When your Canon i550 printer get an Ink Absorber Full error, then you need to reset this Canon i550 inkjet printer.
The following step is procedure used to reset waste ink counter of Canon i550. Nevertheless, this procedure is also applicable for the printer models listed below.
PROCEDURE:
I. Enter Service Mode:
  • Plug in power cable
  • Hold down RESUME/CANCEL button
  • Hold down POWER button
  • Release RESUME/CANCEL button
  • Press RESUME/CANCEL twice in a row
Continue reading complete step below:
How To Reset Canon i550
on May 11, 2014 | Office Equipment & Supplies
Ink absorber almost full
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflowip1000
Jul 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
Jul 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANON 160 PRIXMA
E27 = Waste ink absorber full or platen waste ink absorber full
follow the next step
Jul 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon printer pixma ip 1600 ink absorber full
Dear khalid,
To fix this problem you need to reset waste ink counter of the printer by using General Tools for Canon ip1200 series (General Tools for ip1300 & 1800 series also works on this printer)
Perform following step to reset waste ink counter:
  • Enter service mode:
-Plug in power cable while holding power button.
-Press RESUME button twice
  • Connect USB cable (you may also connect USB cable before entering service mode, no problem).
  • Run General Tool
  • Select USB port
  • Click waste ink counter: Main & Platen
  • Turn off the printer then turn on and run your printer as usual.
I think it will be more helpful with picture enclose. For I cannot insert image more than 150 kb here, I suggest you to visit Canon Inkjet Printer Forum. I have discussed this topic before.
Please rate me.
Regards,
Nov 26, 2008 | Canon PIXMA iP1600 Printer
Canon ip2000 reset ink absorber
Waste Ink Counter Reset:
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Could you resend the solution you had for me?
do you have a manual on this printer?
also, see this for more assistance
Apr 06, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
75 people viewed this question
Clive
Clive
old marine
old marine
Ekse
