Question about Garden
Install and set points and timing in a stihl chainsaw 041
How do I install and set points and timing in a stihl chainsaw 041
5 Suggested Answers
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Where to get points for 016 stihl chainsaw?
Stihl Chainsaw Parts ' Chainsaw Parts ' Discount Online Parts
https://www.discountonlineparts.com/chainsaws/?b=stihl
  1. Cached
  2. Similar
Quality Stihl replacement parts, cheap and quality available online.Handlebars and Housings · ‎Bar/Chain Combos · ‎Stihl 041 Cylinder Assembly ...
Stihl Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b354/Stihl-Chainsaw-Parts
  1. Cached
Stihl Chainsaw Parts - Shop online or call 800-269-2609. Fast shipping. Open 7 days a week. 365 day return policy.
Chainsaws ' Parts, Accessories, Reviews & Pricing ' STIHL USA
https://www.stihlusa.com/products/chain-saws/
  1. Cached
Choose from the wide selection of reliable, dependable and high performing STIHL chainsaws with low-emission technologies and quieter, more fuel-efficient ...Homeowner Saws · ‎Professional Saws · ‎Farm & Ranch Saws · ‎In-Tree Saws
Stihl Chainsaw Parts ' eBay
www.ebay.com/bhp/stihl-chainsaw-parts
  1. Cached
  2. Similar
Find great deals on eBay for Stihl Chainsaw Parts in Garden Chainsaws. Shop with confidence.
Home ' STIHL
en.stihl.ca/index.aspx
  1. Cached
  2. Similar
STIHL - Information about the STIHL Group and our extensive range of chain saws and ... About us More than the world's most successful chain saw brand. stihl chainsaw Google Search
Nov 23, 2016 | Stihl Garden
Any complaints of saw catching fire?
Not really, but if you've had the issue, maybe the vent tube is allowing gas to be dripped into the carbuetor compartment behind the filter. Sometimes, when held horizontally, they will leak a bit out and older saws sometimes have the vent line to deteriorate from the alcohol in todays fuels causing a few drops of gas to escape. I've worn out two 041 Farm Boss saws and never a problem other than normal maintenance.
Mar 15, 2015 | Stihl 041 Av, Farm Boss Chainsaw Intake...
Now spark on a stihl farmboss041 chainsaw
The best thing and not so cheap is to replace the points with a electronic ignition coil. We do this at our shop all the time.
Sep 26, 2012 | Stihl Garden
Stihl 041 chainsaw manual
Try here--->STIHL REPLACEMENT PARTS.
Please post back! Thumb it!
Oct 04, 2010 | Garden
How do I find Stihl 041 s/n with silver sticker gone?
you cant. that is the only serial number on the machine
Apr 16, 2010 | Garden
Shihl 041 chainsaw what is the proper carburetor settings?
set both the H and the L jets at 1 1/2 turns out and then fine tune it from there . This is usually a final setting . hope this helps you
Oct 02, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
981 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
