Hi,this is quite a common problem on these,before you put it into gear pull the lever in two or three times,this will loosen up the clutch plates a little,if i am right it normally only happens when the bike is cold?,the cause is the oil in the gearbox(wet clutch)is probably a little bit heavy,this is why bikes use a multigrade/friction modified oil,hope this helps...cheers
