Question about Electrolux EOG9330 Gas Double Oven
Overheats and turns off and controls are really hot you can turn it on again when it cools down
  • 269 Answers
It sounds like the cooling fan under the top and behind the controls is at fault.Either the fan has burnt out or the safety cut in Thermostat has failed or both.The fan would cost € 45 Euros in Ireland.The part number is 3117704001.
Hope this helps
Posted on May 12, 2010
Fan oven over heating
I would contact the manufacturer .there could be a recall on it if you make them aware of the problem .
Dec 12, 2015 | Ovens
Hi, I have 90 AJC 06 GC. AEG single oven. At thhe moment when the oven is turned off the cooldown fan will not turn off so I have to turn it of at the main fuse box. Also sometimes the oven turns itself...
The oven cooldown fan will sometimes run for 10 to 15 minutes after turning the oven off. This enables the outer shell of the oven to cool down. Most ovens also have an inbuilt thermal overload in the outer shell. If the temperature in the outer shell gets too hot it will open circuit the oven power until it cools down a bit.
Feb 10, 2011 | AEG Ovens
The fan copntinues to run after oven is turned off
Most electric ovens have 2 fans. One is a fan forced fan at the back of the oven cavity that you can generally see spinning when the oven/fan forced option is selected. The other is a cavity fan which is situated between the outer skin of the oven and the oven itself. There are generally located at the top of the oven. Because the oven is a wall oven that sits in a tight cavity it cannot cool down easily. The job of the cavity fan is to cool this cavity down by blowing the hot air in the cavity out a small hole, normally in the front of the oven. When you turn the oven off this fan might operate for 5 to 10 minutes until the oven cavity cools sufficiently. If there was no cavity fan the oven and/or cupboard would overheat.
Feb 06, 2011 | Viking Designer DESO127SS Stainless Steel...
Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Dec 31, 2008 | Baumatic B180SS And B60SS (Bundle)...
Baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Won't turn off
Sounds like maybe a wire burned off of an element terminal and shorted to ground. This would bypass the thermostat, so to speak, and continue to heat at 1/4 wattage. The only way to control this failure would be to turn off the power to the oven, but it won't reset until the burned wire is repaired.
May 27, 2008 | Maytag CWE4800A Electric Single Oven
F-23 error code
this sounds like an overheat problem this unit has several fans that run at different speeds any one of which could be compromised you will need an engineer to sort out
ring 08705 678910 for service and advise
good luck
Nov 19, 2007 | Gaggenau EB 270/271 Electric Single Oven
Oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
May 19, 2007 | Electrolux EOB6636X Ultrafan Electric...
Electrolux EOG9330 Gas Double Oven Logo
193 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
