Question about HP w1907 LCD Monitor
Is there anywhere on the back of the computer i can plug a phone
I have a phone line to my modem, is there any where on the back of the computer i can plug the phone itself?
  • HP Master
  • 4,924 Answers
Some computers have ..but it is just for dial up connection to the internet ..if you have a line in the modem.. and your provider supports phone lines..you can use that with no problems ..but get in touch with the provider and make a demand in this sense..
Posted on Apr 29, 2010
Testimonial: "thank you for the info"
PK5001 solid red DSL light
The trick I found for this is amazingly simple. Take the phone line out from your DSL modem and plug your phone line temporarily into an antique regular telephone for a second, check that it has a dial tone, and plug it back into your DSL modem. Your red light should go green in a minute after plugging the phone line back in. If you leave your computer idle too long, I think the phone company senses no activity and kills the connection after a few dead minutes, and the signal gets booted into some electronic alley. Also put tinfoil over your splice connectors as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 04, 2014 | Computers & Internet
My wife yanked the phone line from the wall and thats when my 2 wire DSL gateway model 2701HG-B modem quit working i plugged into other parts of the house But i just keeps blinking red like its still...
Hello.
Try to unplug power on back of your modem. Let the phone line plugged in. Wait 10 seconds and plug the power back.
Wait about 1 minute and try it with your computer. This procedure will reconnect using a new IP address on your internet service provider.
It should work if you don't have a router. If you have a router attached to your modem, unplug power on both then plug your modem first and wait 1 min. Then plug back your router and wait 1 min. Try your internet connection after doing it. If you still don't have connection, try to restart your computer.
Hope this helps!
Feb 15, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    I have a phone line hooked to my modem, is there anywhere on the back of the computer i can plug the phone itself?
    It depends on the modem. If yours has a phone out jack it'll be next to the line in jack.
    Apr 29, 2010 | HP w1907 LCD Monitor
    I have dial up internet connection. As soon as I placed the connection in the new computer p6340a the phone line was dead. this should not happen until a connection is made. Ted Andrews
    If your modem is fried, this can result in a dead line... disconnect the line from the computer and test the line with a phone... if the tone is present, then connect the line back to the pc... If the line goes dead, you have a faulty modem or corrupt drivers
    Apr 12, 2010 | Computers & Internet
    A cable is not plugged into the network Adapter "Local Area onnection" where is the local area connection suppose to go?
    This just means, that you don;t have a phone line, or a RJ45 line
    plugged into the computer.
    If you have a cable modem, then a line (rj45) runs from the modem
    to the Ethernet port in the back of the computer.
    You need to plug something in or us wireless to get on to the internet.
    So it depends on what service you have depends on what you plug it.
    If you need anymore help just post back, let us know what service you use.
    Cable,phone, satellite.
    Feb 14, 2010 | E-Machines eMachines Monitor E15T4
    Modem won't connect to internet. OS: WinXP Pro SP 3. ISP: Earthlink DSL. Modem: ZyXEL P-660R-D1 (supplied by Earthlink) connected to computer with ethernet cable. Modem includes double filter for phone...
    maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
    Jun 19, 2009 | Computers & Internet
    No Dial Tone on phones or modem
    possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
    Jan 30, 2008 | HP Compaq Presario Media Center SR1750NX...
    if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
    good luck
    wg
    Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
    Telephone dont work
    That light is indicating that you have a phone off the hook, a short in one of your phone lines, or a bad modem. Unplug the phone line from the back of the modem. If it stays solid, plug it back in and go and disconnect every phone in your house. If it stays solid you have a phone issue. Plug them back in one-by-one and see which one causes it to start blinking. If it doesn't go away after unplugging all your phones, you have a phone line issue. If it is still blinking after unplugging the phone line from your modem, your modem is bad.
    Dec 30, 2007 | Arris Touchstone 450a (CM450) Modem
    HP w1907 LCD Monitor Logo
    37 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
