Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Can brushes on the electric moter be replaced? Hoover Scrub ans Spin
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
No. replace the motor. Take it to a vac shop
Posted on May 01, 2010
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Jul 23, 2009 | Hoover F7431-900 SteamVac Vacuum
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
