Question about ASUS P5GD1-VM Motherboard
Need to upgrade Alienware PC with P5GD1-VM
Need to upgrade on this PC - but am unsure what power supply and card this motherboard will support. Can anyone advise what max wattage power supply could be used? Thanks
    President:
  • 1,447 Answers
You need 24 connection power supply 500 watt
Posted on Apr 29, 2010
I want front panel conection details
http://www.ixbt.com/mainboard/images/roundup-i915g-sep2k4/p5gd1-vm-board.jpg
http://www.iusermanual.com/motherboard/asus-p5gd1-pro-motherboard-manual.htm
You can download the driversfrom ASUS WEB site. http://usa.asus.com/index.aspx So please go there website For download clickhere Or http://support.asus.com/download/download.aspx?SLanguage=en-us Suppose, you need driver for, ASUS K8V-VM
Product =Mother Board So Series= (Socket NO.eg. 754 etc.) So Model= (Model no will be K8v-vm) And please select the O.S (XP / VISTA/ WINDOWS 7) version of the drivers that matches your P.C and search. Now you can download easilyone after one. Hope it will help you.
Dec 25, 2010 | ASUS P5GD1 Motherboard
ASUS P5GD1-VM Motherboard i want to know which graphic cards i can upgrade?
You should go for a PCI-E based card(PCI express ).It should be an 8X AGP card as well. If you need any further info please feel free to ask.
Sai.
Oct 01, 2010 | ASUS P5GD1-VM Motherboard
My geforce 6600 wont give a signal when used with this mobo, why?
Open you're manual to page 2-22. Make sure, Booting Graphic Adapter Priority is set to:
[PCI Express/Int-VGA]. Save and exit the bios. You're system will auto reboot. When you're screen goes black, press and hold the power on button until you're system shuts off. Install the 6600 video card. Double check the 6600 card. Most PCI-E cards need additional power connected to it to run.
If you need the manual you can open the link provided; http://dlcdnas.asus.com/pub/ASUS/mb/socket775/P5GD1-VM/e1881_p5gd1-vm.pdf
Hope you find this helpful!
Cheers'
Mike
Mar 27, 2010 | ASUS P5GD1-VM Motherboard
ASUS P5GD1-VM motherboard not booting when powered on
First are you sure it is the CPU fan and not the Power Supply fan? Open up the case and make sure the power supply cable is snug into the slot. Make sure that Pin 1 is lined up with Pin 1 on the motherboard. There should be a notch or red dot or different looking Pin to show you where pin 1 is...sounds like it may be a connection problem from power supply to motherboard...try that and let me know what happens we have other options but have to start somewhere..
Mar 06, 2009 | ASUS P5RD1-VM Motherboard
PC not booting up- no signal, HDD not engaging.
You mentioned that you hear beeps. These beeps gives you the answer of what is the problem. It could be RAM, videocard or maybe the main board itself. It depends on the BIOS that you have (e.g. Phoenix, AMBIOS, etc.) you can see it on the mainboard. You can look on this website on how to identify beep codes:
http://www.bioscentral.com/
It might usually the problem of either power supply or your RAM. So make sure you installed them correctly..
Mar 01, 2009 | ASUS P5GD1-VM Motherboard
Upgrade question on ASUS P5GD1-VM/S mobo
According to the manufacturer it will support P4/celeron 3.6Gz+ procesors. And memory should be Dual channel memory architecture 4 x 184-pin DIMM sockets support max. 4GB DDR 400/333 non-ECC memory. Hope this gets you up and running.
Jan 31, 2009 | ASUS P5GD1-VM Motherboard
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
I Don't have video signal
If this is onboard video, plug in a separate video card.
If it's already a separate card, try a different one to narrow down the cause.
Oct 16, 2007 | ASUS P5GD1-VM Motherboard
ASUS P5GD1-VM Motherboard Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
