Question about Amana ABB1927DE Bottom Freezer Refrigerator
My bottom freezer (It's an Amana) frosts up and both the freezer and the top departments start getting warm. I turn it off and defrost it with a hair dryer and then I'm find for 3 or 4 months or more. I did this a few weeks ago and it's cooling fine now, but it seems to be running louder, sometimes very loud for about 15- 20 minutes. The unit is about 10 years old.
  • Amana Master
  • 43,501 Answers
Posted on Apr 29, 2010
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Bottom freezer frosts up,top refridge gets warm
It sounds like you have a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Not blowing cold air
Most likely evaporator coils are iced near solid...few hours unplugged would have helped just a little...needs major defrosting though.
The automatic defrost cycle will never fix it when it gets this bad...if it's still working yet.
I have one of these and have had to use heat gun/ hair dryer more than once to defrost it.
Probably the cause...which will need fixed or it will do it again sooner or latter...is the melted frost/ice goes down a little drain tube and dumps into tray to evaporate above coils...this tube gets plugged first with dust and then when melted frost drains and stands in tube the tube get plugged with frozen water.
You see it is important to unplug or fridge will self destruct.
Mar 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Bottom freezer coils freezing up
DEFROST PROBLEM CHECK YOUR DEFRST HEATER,DEFROST T-STAT=LOCATED BEHIND THE PANEL BOTH ARE LOCATED ON THE COIL WITH A OHMETER OR DEFROST WITH HAIR DRYER IT WILL HELP FOR 10 DAYS OR SO.
Jun 25, 2008 | Amana ABB1927DE Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Dec 09, 2007 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
