Question about Whirlpool 24 in. DU810CWD Built-in Dishwasher
Squeaking when dishwasher is running out water.
Sort of loud sqeaking and sometimes almost a grinding noise.
Look just below the countertop, where the dishwasher is located. You should see a couple of mounting brackets securing the D/W to the countertop. The "squeak" your hearing may be metal on metal?
If not, take a peak below the D/W door (you got it...put your ear to the floor!) - you should see two set screws securing a kick plate. Remove it. Inspect those pedestal feet in front- at a minimum you want to see them "touching the floor".
Beyond those two suggestions (50/50) which just may do the trick, it is likely to be a worn belt-
Though, I'm NO applicance guy - just a problem solver.
Good luck
Posted on May 16, 2010
It is making loud sqeaking noises when turned on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 04, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Sqeaks very loud, still heats and turns.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 17, 2011 | Dryers
Sqeaks and won"t spin
heatman101
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
Neptune dryer sqeaks while running
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryeer
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jul 03, 2010 | Maytag Neptune MDG9700A Gas Dryer
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Loud rattling grinding noise when pump is running, no water enters the machine.
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Feb 01, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Grinding Noise
you an remove lower access panel run d/w and nextime it makes the noise grab a flashlight and take a look under. sounds like a vibration issue( especially since you hit it nad it stops) perhaps your copper water line is rattling or your drain line is hitting motor causing noise
Feb 23, 2008 | Dishwashers
Dishwashers Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
