Question about Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher leaves dirt on top rack
My dishwasher leaves dirt and grime on the top rack dishes almost every time I wash. I scrub my dishes before I load them in so it isn't food. It isn't the heating element because I have now had two dishwashers with the same problem. The first one I thought was going bad so I bought a new one and STILL have the same problem! Please help!
  • 56 Answers
Still worth checking for hot water though, stop machine when you know its at a stage where the water is suppose to be hot. Also when the machine is loaded that the top arms are able to spin freely without hitting anything. Also make sure top arm holes have not got any old foo stuck in as this will stop them from spinning properly. Open door during wash and close door then re open to see how far around it has gone. Not as powerful as the bottom arm but shouldnt be that far of.
Posted on Jul 10, 2010
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Tip
Clean Your Dishwasher And Remove Odor
<br /><span> <ol> <li>Using a small brush (old toothbrushes work well) dipped in hot soapy water, go around the door of the dishwasher taking care to get into the grooves and crevices of the rubber seal. Most likely, you'll be surprised at the debris that has built up, especially at the bottom of the door and around the hinges on the side.</li> <li>Scrub well. You may need to use a soft abrasive cleanser, such as Soft Scrub&reg; to remove the dried and baked on grime.</li> <li>Using a household sponge dipped in hot soapy water, wipe off the dirt and grime that you stirred up with the brush. Go over the inside of the door and scrub any obvious areas inside the dishwasher that may have stuck-on food, such as out of reach corners.</li> <li>Pull the bottom rack out and examine the drain area. Wipe around it to be sure there are no hard chunks that can plug the drain, cause damage to the pump or scratch dishes. You'd be surprised at what dishwasher repairmen find </li></ol></span>
on Apr 04, 2011 | Dishwashers
Top rack of dishwasher seems to deposit particles of food on to glasses so not only are they dirty at the end of the cycle, the pieces of food particles are difficult to scrub off them. This happens with...
check the holes on the sprayer for the upper rack, somtimes they get pluged up and the top rack dishes wont get sprayed off. if they are pluged remove them and wash in a sink
Oct 26, 2009 | Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Hard sand substance on dishes after washing & Soap not dispensing
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jun 19, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
LG dishwasher wont clean top rack dishes
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Jenn-Air JDB6510 Built-in Dishwasher Logo
222 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
