Question about Car Audio & Video
Audiobaun 1800-dt amp smoked now have alot of engine noise
I have a audiobaun 1800-dt class d mono amb i viewed the amp let off some smoke while it was in operation the amp still is pushing alot of power but i now have alot of engine noise coming through the subs
  • uno_1 May 11, 2010
    you probably burnt out and ground isolating loops on the amp... try giving it a fresh ground, grounding the RCAs, all this will only put a band-aid on the problem though... time for a new amp
    Problem Solver:
  • 13 Answers
Depending on the the amp make, it might be a resistor or a fuse that burnt in the grounding circuit, explaining the engine noise
Posted on Apr 30, 2010
Uncontrolled downshift of 1994 c220
no 4-3 or 3-2 downshift
uncontrolled downshifts outside range of kickdown switch
poor acceleration from stopped position
parking pawl will not engage
selector lever does not engage in r or p
engine will not start in p or n position
smoke in exhaust (fluid loss)
fluid loss between torque converter & primary pump
howling noise when changing gears (under full load)
howling noise which increases as engine rpm increases
1st gear & reverse too loud
3rd gear too loud
rattling noise at 1500 rpm in all positions except r
light grinding noise in p & n positions
rolling noises when driving in reverse
vacuum control circuit
Vacuum Control Valve (E300D & S350D)
Vacuum Amplifier (E300D & S350D)
Dec 02, 2012 | 1994 Mercedes-Benz C-Class
Started engine, heard a grinding noise & smoke
Sounds like one of the accessory pulleys locked up and smoked the serpentine belt. The air conditioning pump would be my first suspect, but grab all the pulleys and turn them. The problem pulley will probably be discolored, and have belt residue on or near it.
Sep 03, 2011 | 2001 Dodge Ram 2500 Truck
96' mercury sable smoking from pipe alot and knocking. Under the hood with alittle smoke won't pick up speed
didnt state color of smoke if blue smoke burning oil internal damage to engine and with knock could be rod--bent/stuck valve [blown engine ] white continuous smoke burning coolant usually a blown head gasket but add knock engine damaged
Jul 07, 2011 | Mercury Sable Cars & Trucks
What will cause my Toyota Hilux to smoke with loud engine noise at high rpm? When accelerated to speeds of approimately 130km/hr, the engine races of, which feel like no control to the vehicle, smokes (...
If there is a blockage in the engine breather, that can cause this to happen and if not corrected, in a diesel, can cause runaway and it will destroy itself.
Jul 23, 2017 | 1995 Toyota Pickup
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
It smokes alot from the hood
check your raditator hoses, water pump and your thermostat. your engine could be overheating in which the radiator fluid can't get to it to cool it off.
Sep 22, 2009 | 2003 Chevrolet Impala
My 1994 Ford Thunderbird now smokes when I start it - no noises in the engine, but smokes like crazy. Check engine light is one now?
state what color the smoke is. White smoke is antifreeze. Gray smoke is fuel, and black smoke is oil. Also have the computer scanned so you know why the light is on.
Apr 25, 2009 | 1994 Ford Thunderbird
Boss 2500GT mono block car amp white smoke after 5 mins
I'm not familiar with this particular model but this appears to be the filter inductor in a class D amp. If I had to guess, the white smoke is from the filter capacitors connected to this inductor.
You should check with Boss to see if it's available. If it's not, you can re-wind it. You'll need to measure the diameter of the wire to determine its gauge.
If the filter caps vented, you'll have to replace those also.
May 26, 2008 | Car Audio & Video
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
