Question about Samsung LN-S4692D 46 in. LCD HDTV
Remove base from monitor - Samsung LN-S4692D 46 in. LCD HDTV
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
To remove the base first lay the TV face down on a soft quilt or couch, the base is held on with four screws that go into the back. With the screws removed pull the stand/base straight out the bottom.
Thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Roety
Posted on Apr 29, 2010
How to remove base from gateway hx2000 monitor
You need to find the original instructions for putting the monitor together, or you could accidentally break the base from the monitor if you attempt to remove it the wrong way. Try Google.
Jul 11, 2014 | Gateway HX2000 20" Monitor
Hello, I can not split the base for the monitor hp 1730, can assist me please, stuck in the laptop position
You have to remove four screws in order to separate the monitor base from the monitor.
Check the manual (section "Setting Up The Monitor", subsection "Removing The Monitor Base") for images of the location of the screws.
You can download the manual using this link: http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01129544/c01129544.pdf
Jun 13, 2011 | HP 1730 LCD Monitor
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
Is there any way to remove the base from the Optiquest Q7 monitor? We would like to attach the monitor directly to the server rack.
On mine I pulled on the round cover where the base attaches to the screen. It came off and there are 4 screws underneath. Remove those screws that hold on the base
Jul 15, 2009 | ViewSonic OptiQuest Monitor
Swivel base removal
In the back of the swivel there is a small release lever... push down (?) then with other hand hit the swivel base towards back, then lift unit up.
May 11, 2009 | Gateway VX930 19" CRT Monitor
Remove base completely from envision monitor
after removing all the screws, i used a knife to remove the plastic casing surrounding the monitor. that exposed four screws that when removed, released the base from the monitor. it was just a matter of putting the casing back together. thanks
Jan 30, 2009 | Envision 19" Widescreen Flat Panel LCD...
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Samsung LN-S4692D 46 in. LCD HDTV Logo
337 people viewed this question
Henry  Thomas
Henry Thomas
